Ahh! Need refilling!
Posted 27 December 2006 - 03:45 PM
well two things are, see my crude diagram:
so those two things are empty, thats the radiator on the right and engine oil in the middle, right?
Please tell me what to fill up (and what with) and how much as my mini wont start!
sorry for being such an idiot, im new to the motor world
thankyou!
Posted 27 December 2006 - 03:47 PM
The one on the right is the radiator, needs refilling with roughly 50% water and 50% anti-freeze.
Posted 27 December 2006 - 03:51 PM
Posted 27 December 2006 - 03:52 PM
Moved.
Posted 27 December 2006 - 03:54 PM
I'll check dipstick.
Posted 27 December 2006 - 03:57 PM
Posted 27 December 2006 - 04:00 PM
Off to spend more money on the mini now then What oil does a 998cc take? from 1987.
Posted 27 December 2006 - 04:02 PM
Posted 27 December 2006 - 04:05 PM
edit: beaten to it but quite chuffed to find i use the right oil! lol
Edited by incrediblerog, 27 December 2006 - 04:06 PM.
Posted 27 December 2006 - 04:23 PM
Posted 27 December 2006 - 04:30 PM
If its just low, as in at the low level on the dipstick or just below it then just start it and let it run for a couple of minutes then let it settle for about 5 minutes then drain the oil out. Warming it up just helps all the oil & sludge to run out.
If you dont know when it was last changed and the oil is really sludgy and black when it comes out, its worth changing it and the filter then doing it again after 50 miles or so just to flush it out a bit.
Make sure you do the filter at the same time too....
And for the record, I use 15w 40 oil Halfords Blue bottle
Edited by Jimmyarm, 27 December 2006 - 04:32 PM.
Posted 27 December 2006 - 04:33 PM
Ideally you need to be checking for a spark and fuel as well.
Posted 27 December 2006 - 04:35 PM
When you say you bought it with a low level of oil, how low is that ? If there is none in it then it shouldnt be run at all ! There could be major internal damage.
the thing is that it leaks so its oil has gone down with time. yes i think i'll flush it as for VRT (our mot) i want it to be in tip top condition
i'll see when i come to oil.
Posted 27 December 2006 - 04:41 PM
And fix the leak !
