Newb in need of a mini pro
Posted 28 December 2006 - 11:03 AM
My mini has decided that it doesnt want to start this morning. Basically when i turn the key nothing happens. The starter motor doesnt even click and the ignition lights dont go on in the dash.The headlights go on but the cd player, heater, indicators or even the hazard lights will not switch on. I tried a push start as well and it wouldnt even try to start.
I have tried WD40ing the distributor, all the leads and fuses but it still wont start. I have checked the battery and theres plenty of juice left. Iv got a feeling its a wiring problem but which wires do you think im best looking at? or what else do you think could be a problem?
All help wll be greatly appreciated?
Luke
Posted 28 December 2006 - 11:10 AM
Hi Mini gods hope you all had a nice Christmas.
Luke
either the battery is completely empty or you need a new starter by the sounds of things.
Posted 28 December 2006 - 11:30 AM
Check the battery connections are both clean, attached and that nothing else is touching them (such as an amp ).
Move to the front, get a multimeter and check you are getting 12v+ at the starter solonoid.
Check all the fuses, pop them out and give them a clean with a wire brush as well as the holder itself and check the inline fuses (behind the filter) as well.
Check your earth strap is on and not broken, if poss take it off and give the connections at the end a good clean with some sandpaper.
Edited by Jimmyarm, 28 December 2006 - 11:32 AM.
Posted 28 December 2006 - 11:53 AM
Posted 28 December 2006 - 02:30 PM
