Edited by mini16, 29 December 2006 - 07:45 PM.
i have fitted door poppers but...
Posted 29 December 2006 - 07:44 PM
Posted 29 December 2006 - 07:50 PM
Posted 29 December 2006 - 07:52 PM
thats a possibility although i will have to goin a longer cable, AAaa bike gear cable will do got lots of that, yep that will do cheerscan it not go at the very bottom of the doors like the central locking kits ?
Posted 29 December 2006 - 08:00 PM
Just as an add on... Have you thought about locking yourself out with the keys in the ignition and the engine still running? Not that I have done it about 5-6 times . I have fitted push switches under the wing mirrors like the TVR's have and sorted a locking mechanism for the whole lot so that the doors(the switches are active) are unlocked when the engine is running. If you want some circuit diags give me a shout and I will russle some up!
Also, if you have got a spare channel, wire it up to the horn! Hours of amusement when you get bored. Its like watching Beadles About!!!
Posted 30 December 2006 - 05:07 PM
if you wouldnt mind them diagrams would be nice please? also its great as i can set the alarm not beep then pause bit a constant beep on the horn, i can do this on the key fobb very funny. also well loved by the neighboursThe problem you might have by mounting them in the bottom of the door is that you might not get enough pull from the solenoid. I tried this with my kit and it didn't work. I ended up seriously modding the internal door skin and mounting them in line with the lock and they work great... BUT, I now have a solenoid to rest my elbow on when the window is shut. And it hurts like when doing a three point turn and you catch your elbow on it. However, with some fibre glass and a little inspiration I am going to make my own door cards witha nice elbow ridge like modern motors.
Posted 31 December 2006 - 08:33 PM
Basically the soloniod is in the very bottom of the door with the cable pointing up , the cable then goes through a small hole and around asort of pivit to change from a downward pull to a sideward pull to pull the rod, i then goined the solonoid cable to a bike brake cable by a small thing used to hold cables together very small.
here is a sort of diagram to help sorry about the untidyness done it on paint
the only thing is getting the positive cable from door to car as there is no holes yet
Edited by mini16, 31 December 2006 - 09:04 PM.
Posted 04 January 2007 - 08:18 PM
Poppers circuit diag
The relays are the noraml automotive type and I used the two that came with the kit. And then bought another for the lock/unlock relay. You can use this as a kill switch as well but I can't remember off the top of my head how I wired it in. Will get at it in the next couple of days to figure it out !!
Hope this helps!
Jez
