HELP! Dizzy, Ciol, NO Spark as yet
Posted 31 December 2006 - 04:50 PM
Got Metro 1275 with electronic ignition, (i think) out of my 1989 mini thirty
Put 1987/88 998 in for time being
Cant fathom the wiring, i think i have something missing
Using coil from 1275.
Black and white from coil to dizzy, the rest i cant remember, the mini is at the bottom on the garden and its raining.
Can somebody tell me if im gonna get anywhere with the duccelier coil that the 1275 was running, and a brand new ducellier dizzy for a 998 a+ with points?
no spark what so ever
dont think its wired right
can some one please tell me what needs to be where, and what wires go where?
do i need a wire from the starter solenoid to the coil? because when i checked this, it only had 12v when the engine was turning over on the starter, not when the ignition was simply on. obviously
any help much appreciated
thanks in advance
ed
Posted 31 December 2006 - 04:54 PM
Here, click me, I'll do all the leg work for you...
Posted 31 December 2006 - 05:07 PM
I know it might not be perfect, but i just need to see if the thing runs, before i finish the changeover
yeh i will buy the right coil, but not until i know the engine is sound
so any help in getting me that far would be really appreciated
ed
Posted 31 December 2006 - 05:22 PM
Posted 31 December 2006 - 05:27 PM
The dizzy should also have 2 wires to it, one to go to the +side of the coil, and one to the -
This should be all you need, but the coil may not be any use...
Posted 31 December 2006 - 06:03 PM
But I suppose it will be good enough to actually get the engine running.
The wiring harness near the coil should include a Pink/White wire and a Pink/Yellow wire. Both of these need to be connected to the positive terminal on the coil. There should be a couple of White/Black wires also, one is to connect to the dizzy and the other is the tacho trigger wire. Both of these need to be connected to the negative terminal of the coil (well, the tacho one doesn't actually need to be connected at all obviously). One of these as I said should go to the LT side of the dizzy and make sure that everything in the dizzy is connected, including the wiring to the external condenser. Also make sure that the carbon brush is properly earthing the baseplate to the spindle (dodgy Ducellier carp). That's it.
Yes it is correct that the wire from the starter solenoid is only live while the starter is cranking, that's the cranking bypass for the ballast ignition system and is the whole point of ballasted ignition. The Pink/White wire should show something between 9 and 12 volts while the ignition is switched on, if you supply a ballasted coil with 12v it will fail soon and so will your points. There is no difference between the coil for a 998 and a 1275, the only thing that matters is that the coil you are using is designed for ballasted ignition. It will say ballasted or 9 volts or something like that on it if it is.
It seems Jammy is right, I really must do an ignition systems FAQ.
Edited by Dan, 31 December 2006 - 06:04 PM.
Posted 31 December 2006 - 06:40 PM
My new points dizzy, has only one wire, not two
i shall go try it in the morning, after the hangover subsides
but in the long run, what about puttuing the electric igbition from the 1275 onto the 998?
is it possible?
well i guess it is, but is there a crankshaft sensor needed on the 998??
i cant seem to find one on the 1275, but i thought electric ignition used one?
or is this another sort altogether
thanks again
ed
Edited by edjohnson, 31 December 2006 - 06:41 PM.
Posted 31 December 2006 - 06:57 PM
The electonic ignition from the 1275 will be all wrong for the 998. The system is entirely contained within the dizzy and doesn't use a crank sensor (some do but it's uncommon, mostly it's fuel injection systems that need a crank sensor). Electronically it will work with the 998 but mechanically it won't be great. The advance curve in that dizzy is designed for the 1275 and the unit would need modifying with new springs and weights to work well on the 998 but it can be done and that's what I have on my 998.
The easiest way for you to get electronic ignition on a 998 is to fit a late 998 Lucas dizzy (a 45D4 or a 59D4) from as similar an engine spec to yours as possible and a Lumenition Magnetronic or Aldon Ignitor electronic module to run it. The lumenition one is basically the same electronic module as fitted to the 1275 64DE4 dizzy but re-packaged.
You must have a 12v ignition feed there somewhere which was running the electronic ignition on the 1275 engine. You won't need this with a ballasted CB (contact breaker) ignition system but you can make use of it if you fit a new electronic system, whether you use a ballasted system or not. Ballasted is far better by the way.
Posted 31 December 2006 - 07:29 PM
I'm going the other way 998 to 1275, mechanical to electronic, I know the disty needs switched live & live from coil. But don't know on the disty which is which. One terminal is facing along the amplifier & the other across can you identify them for me. Also the disty has been removed from the engine, I have put it back in but how to I get it set up for static timing, just getting it somewhere near to get the engine started, I can then strobe it & eventually going to get it rolling roaded once complete.
Sorry for butting in but asked the question in another post & got no replies.
Alan...
Posted 31 December 2006 - 07:42 PM
Posted 31 December 2006 - 08:59 PM
Can't answer off the top of my head but I can check for you tomorrow.
That would be great if you could thanks
Alan...
Posted 01 January 2007 - 03:01 PM
stuffed the old 1275 electronic dizzy on this morning
ran ok
gonna connect all the coolant system properly, put the wheels back on, and swap the manifold for the one with the tapping for the vacuum on the servo doh!! (didnt realise the donor engine had the wrong manifoild on til it was too late.
did they do electronic ignition on 998 metros?
ed
Posted 01 January 2007 - 04:48 PM
Posted 02 January 2007 - 01:11 PM
has anyone got any ideas what i would need to modify to achieve a more suitable advance curve for my 998 from a 1275 dizzy?
im really keen to keep the electronic ignition now.
but cheeply
ed
Posted 02 January 2007 - 06:16 PM
