Chitty Chitty Bang Bang
11 replies to this topic
#1 Dexy
Dexy
  • 140 posts
Posted 02 January 2007 - 02:42 PM
Anyone Who Can Help Please!!!
I was giving the engine a good clean so moved all the electrics out the way and wiped down with sparkplugs with an old cloth (1 of many :gimme: ) Went to start her back up and she will turn over at 10000 rpm with the choke but when i drop the choke to less i get spurts and splurts then red light on the dash comes on and she cuts out. also when i try to accelerate i get loud bangs from the engine which gets super hot!?!?
:'( :'( Please any help!!! :'( :'(
JAi
#2 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 02 January 2007 - 02:45 PM
check all your earths, check you've wired the coil correctly, and check your plugs are in the right sequence....
basically go over everything you've done..
P.S> also did you mess with the carb?
Edited by Retro_10s, 02 January 2007 - 02:46 PM.
#3 Dexy
Dexy
  • 140 posts
Posted 02 January 2007 - 02:48 PM
Ah! i kinda didnt realise my plugs went in a certin order?!?:gimme:
Yeah i did quick take top off of the carb
Sorry if i sound abit dumb, its my first car and first time gettin my hands dirty
JAi
Edited by JAi, 02 January 2007 - 02:49 PM.
#4 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 02 January 2007 - 03:20 PM
DO NOT RUN THE CAR UNTIL THE PLUGS ARE IN THE RIGHT ORDER, YOU WILL KILL YOUR ENGINE IN NO TIME.
Number one cylinder is the sparkplug hole on the right hand side of the engine as you look at it. So If i was to write on the sparkplug holes their relevent numbers as you look a the engine, it would look like this 4-3-2-1.
When the engine runs ,these cylinders fire in a sequence which is 1-3-4-2.
The distributor is the object you took the leads off on the left hand side of the engine bay. The dizzy's internals spin ANTI-clockwise... you have four lead sockets on the dizzy cap (not inlcuding the one in the middle)
As you look at the engine wire the HT leads in this order:
sparkplug 1 to dizzy socket on top right
sparkplug 2 to dizzy socket on bottom right
sparkplug 3 to dizzy socket on top left
sparkplug 4 to dizzy socket on bottom left
that's off the top of my head os i'm sorry if i made some mistakes... someone correct me if i'm wrong and if it's an arse to understand lol!!!! (it confuses me!)
Did you fill the carb dashpot (the bit you took off) with engine oil?
P.S> (did i get the dizzy bit right?) it's been a while since i looked at a mini with an engine in lol
Edited by Retro_10s, 02 January 2007 - 03:30 PM.
#5 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 02 January 2007 - 03:41 PM
Dizzy bit sounds right.
I would be more concerned that your engine was going over 10000 rpm when you pulled the choke out ! :gimme: :gimme:
#6 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 02 January 2007 - 03:45 PM
if you didn't fill the dashpot (carb) back up with fresh engine oil, then you need too., with the carb all together as it would be, unscrew the black cap and squirt some oil down the hole, fill it up to the 'shoulder' of the pot.
#7 Dexy
Dexy
  • 140 posts
Posted 02 January 2007 - 04:07 PM
Yeah I re filled it! sorry bout thet typo on the numbers and i will go try the set-up now and will let you know how it goes :gimme:
JAi
#8 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 02 January 2007 - 04:12 PM
come back straight away with results....
#9 Dexy
Dexy
  • 140 posts
Posted 02 January 2007 - 04:24 PM
:gimme: Retro_10s I LOVE YOU!!! :gimme: :w00t:
She's Alive Again!!!!
I think a good clean has made her run alot smoother thanks soo much for your help!!!
Let me know if i can do any banner design or photoshop for you!
JAi
#10 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 02 January 2007 - 04:26 PM
Lol, looks like Retro has an admirer :gimme:
#11 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
JAi
WOOOO I FEEL USEFUL!!! YEAH!
thanks for the photoshop offer etc... i already do a lot though :xxx: it is enough for me to know i gave some useful help and fixed a car! woot!
#12 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 02 January 2007 - 04:27 PM
looks like you have competition Jimmy! :gimme:
