Hi i have looked through the search option and can't find much to help with my question. (maybe i have not looked hard enuff).
Could someone tell me what exactly i need to convert a verto clutch (mg turbo engine) to a pre or non verto. down to the last screw.
as i hear that this is the way to go.
any links or any other info would be great
cheers
verto to non-verto conversion
drc
, Jan 02 2007 11:21 PM
6 replies to this topic
Posted 02 January 2007 - 11:21 PM
Posted 02 January 2007 - 11:41 PM
Complete flywheel (consisting of flywheel, clutch driven plate, pressure plate, clutch cover (diaphragm spring), driving straps (6 or 9), strap to flywheel screws and washers (3), diaphragm screws and washers(3), locktab set, clutch thrust plate and clip), flywheel locking key, flywheel bolt, crank locktab (not in the set AFAIK), clutch plunger, cluth release bearing, plunger adjusting nut and locknut, clutch release arm and clevis with washer and splitpin, clutch pushrod with clevis, washer and splitpin, slave cylinder with mounint bolts and washers, clutch hose, return spring with 2 retaining tabs, clutch release arm return stop screw and locknut, and possibly a new starter motor or swap the ring gear on the flywheel. Read the clutches FAQ, it's very helpful and has lots of pictures.
Posted 03 January 2007 - 12:02 AM
Moved.
Posted 03 January 2007 - 12:15 AM
.......... and a partridge in a pair tree
Posted 03 January 2007 - 10:52 AM
WELL !!!!!!! cheers for that DAN that looks very comprehensive!
Thank you! that answers my question
Posted 03 January 2007 - 11:12 AM
¿What are the advantages?
I have a Verto (I think) and am feeling left out
Posted 03 January 2007 - 12:38 PM
I *think* the advantage is that it can handle more power as standard......as for why, check out the aforementioned FAQ, i read it ages ago and remember it being very informative...if only my memory was half as good!
