Whats worng with my mini???
Posted 03 January 2007 - 04:59 PM
I also tried this in 3rd gear and the same thing happened.
so i was woundering what is wront? Is the timing out or something?
Posted 03 January 2007 - 05:05 PM
Matt
Posted 03 January 2007 - 05:16 PM
Was it raining when this happened ?
Edited by Jimmyarm, 03 January 2007 - 05:20 PM.
Posted 03 January 2007 - 06:45 PM
Posted 04 January 2007 - 04:25 PM
Posted 04 January 2007 - 04:58 PM
Posted 04 January 2007 - 05:57 PM
And when did it last get an oil change and air filter change (full service in fact) too?
Posted 04 January 2007 - 07:09 PM
Posted 04 January 2007 - 07:16 PM
Posted 04 January 2007 - 07:45 PM
I agree a good rolling road tune would help, but my Minis got an LCB & Maniflow exhaust system, K&N cone filter & slightly richer needle but i've yet to get it set up on the rollers.
Till now i've just had it crypton tuned by a mobile tuner who does a grand job, so try getting it tuned and see if that helps?
Posted 04 January 2007 - 11:47 PM
Posted 05 January 2007 - 04:26 PM
As dan said, it could be the coil. When it starts to break down it will cause misfires at higher revs and under load. It could also be the condensor which would have the same effect.
There is a method for testing the coil shown in the haynes manual. The condensor you cant really check (although there is a sort of method in haynes) and its a PITA with new ones as it seems like a lucky dip as to whether they will work or not !
An electronic ignition module would solve it, costs more but you never have to worry about points/condensor again
Edited by Jimmyarm, 05 January 2007 - 04:27 PM.
Posted 06 January 2007 - 11:51 AM
until the electronic module goes wrong. yes it has happened to a fair few folks i know. 1 day it just decides to pack up. not that im saying it isnt a good idea but carrying a spare points and condensor is a good idea incase the leci ignition goes BANG.
