Tracking is way out
Posted 04 January 2007 - 01:26 PM
A brief history.
1. Beginning of the year had new front tyres and tracking set after new lower suspension bushes fitted. All was well.
2. Car took a bit of a nock when the Mrs reversed into it but nothing apparantly changed. At the same time I changed from drum to disks at the from with what I believe is a Mini disk setup.
3. Pull to the right deveolped to the pont of going in circles if I let it so had the tracking checked. They would not channge it as it was WAY out (but still on the gauge) and advised me to get it checked out.
4. Upon inspection, I found that one nut on the end of the right tie-bar was practically falling off so I changed for heavy duty adjustable ones and new bushes again from our sponsor.
5. All seemed well apart from the very slight pull to the right as mentioned at the beginning of this post.
So where do I go from here? The old tiebars were bent, so is this enought to make a huge change when I put the new ones on? The guy said today that its so toed out that you should be able to see it - but he can't?
Suggetions please
Matt
Posted 04 January 2007 - 02:07 PM
or am I missing something here?
Posted 04 January 2007 - 02:15 PM
errm...now you got the nut on why not get the tracking done?
I just did. Points 1 to 5 were there to give an idea of what has happened over the past few months. Sorry if thats not to clear.
Everything is on and tight and seems right - but clearly not? Unless he measured the tracking for a Bini
I'm now thinking if set the length of the tie bars correct!
Posted 04 January 2007 - 02:49 PM
So am I right in thinking that you've just changed your tie-bars, and then you've had the tracking done, and its still pulling to the right?
Posted 04 January 2007 - 02:51 PM
Bent tie bars would certainly make a difference
Did you measure the number of turns to get the track rod ends off when replacing brakes and hubs? Are they 2 pot calipers or 4 by the way?
Your subframe could have been bent when the Mrs hit it....
As it stands today...is it still sterring to the right?
Posted 04 January 2007 - 03:03 PM
You should always get your tracking checked after changing the tie bars, unless you know the tracking was fine before, and the tie-bars you've fitted have been adjusted (if adjustable) to EXACTLY the same length as the ones your replacing.
Tracking was fine until the nut on the tieber loosened and mashed a bush. I then fitted new bar and bushes. I did measure the bars when i fitted I fitted them but not against the old ones as they were bent. I am now doubting the accuracy of that measurement.
Sorry I've replied in the qoute......
No 3. You took it to get the tracking done, they identified it needed doing and suggested you get it done!? Isn't that why you took it to them in the first place!!?
The suggestion was that something was VERY wrong as it turned out there was - one of me tiebars was almost falling off (there was more nut off the thread than on).
Bent tie bars would certainly make a difference.
I agree.
Didn't remove track rod ends. They are 2 pots
She didn't hit it hard - more of a nudge. No body damage except for a dented head lamp ring.
Very slight pull to the right, and the right front is wearing on the inside edge of the tread.
Posted 04 January 2007 - 03:05 PM
Posted 04 January 2007 - 03:25 PM
Sounds like the Garage has made a mistake somewhere, so maybe take it elsewhere and have it re-measured first.
Posted 04 January 2007 - 03:33 PM
Posted 04 January 2007 - 03:34 PM
Possibly, but then he's had a big problem with it pulling to the right, which suggests the tracking needs sorting!You've been told that your tracking is so far out that it's off the gauge and should be clearly visible, yet all looks ok?
As for the comment of the person who you took the car to be checked by... if it'd had been me I have told them that that's why I've brought it here, if they can't sort the tracking why are they providing the service... DOH !
Also maybe worth checking you do actually have mini hubs, and not metro ones ( the distinguising feature is the balljoints, on metros they are sealed units replaced as a whole )
Posted 04 January 2007 - 04:18 PM
I can firmly say they are Mini hubs based on your description. I fully understand the effect that incorrect length of tiebars will have andf for that reason I am going to double chek them agains what our sponsors recommend in the fitting instructions.
So, would a change from drum to disk make any change to the toe of the wheel as long as they are Mini ones? If so then that may be he answer.
Biggav - No not Kwik Fit.
Cheers for your collective help so far.
Matt
Posted 04 January 2007 - 04:30 PM
....where did you get the hubs from, were they definately a matched set?
Edited by TOMMO0302, 04 January 2007 - 04:31 PM.
Posted 04 January 2007 - 04:35 PM
Matt
Posted 04 January 2007 - 05:26 PM
