Should I get a new engine?
Posted 04 January 2007 - 06:18 PM
What he recommended is that I buy another lump from somewhere and put that in instead but they would charge me about £400 to put that in, I could try myself but I have never done anything like that before and don't have a hoist or anything like that and would have to use axle stands, jacks and ramps. Plus I don't know how hard it is to do and where to get a decent engine from.
What would you do in my position???
Any help will be much much apprieciated as my poor little baby is ill
Posted 04 January 2007 - 06:24 PM
Posted 04 January 2007 - 06:32 PM
I was considering just getting a bigger engine but then I expect would have to modify loads to get it to fit right.
Edited by Jumpinjacks, 04 January 2007 - 06:32 PM.
Posted 04 January 2007 - 07:08 PM
are they having you on ?
Posted 04 January 2007 - 08:00 PM
Posted 04 January 2007 - 08:55 PM
I am a little unsure too.i'll bet the gasket has blown between 2 cylinders, and they want to make it all level! that is the only place i can think that the damage could be!! and even so i've driven with a head gasket like that for weeks, a good gasket scraper and its all flat again and its fine!! i would be suspicous personally.
But when I drove it up there the engine made a hell of a rattle and I just made it up our hill going 30mph just. there was no power there at all and the guage was right up into the red from a 1 mile journey up the road.
Posted 05 January 2007 - 12:12 AM
Is it easy to fit? I've heard it is.
Will any Mini or Metro engine just drop in there without any modifications?
If so what's best to go for?
Posted 05 January 2007 - 12:20 AM
"TUNING THE A-SERIES ENGINE" by David Vizard will tell you everything you need to know, and guess works is a good man to speak too... and mini sprocket... and loads of others on here.... don't listen to bungle though, he'll have you fitting square wheels in line with the Cornish MOT Regs!!!!! only kidding bungle
Posted 05 January 2007 - 10:51 AM
If you buy a second hand engine, expect a 998 to cost anything between £0-£100 for a full engine, and a 1275 will be anything between £100-300. £400 to swap an engine is a tad excessive, I'd say it should cost between £200-300!
I'd seriously get the car to a mini specialist.
Posted 05 January 2007 - 10:52 AM
If you buy a second hand engine, expect a 998 to cost anything between £0-£100 for a full engine, and a 1275 will be anything between £100-300. £400 to swap an engine is a tad excessive, I'd say it should cost between £200-300! The problem with getting a second hand engine is that you don't know what your getting, unless you can drive car before you get the engine!
In fact go down there unexpectedly and ask to see the damage, especially the hole in the piston!
Posted 05 January 2007 - 11:03 AM
I could take a picture of it if you guys want to see for an opinion.
Posted 05 January 2007 - 11:35 AM
What do you think?
Posted 05 January 2007 - 12:22 PM
Posted 05 January 2007 - 01:01 PM
