CB radios
130 replies to this topic
#76 edd
edd
  • 94 posts
  • Local Club: nope not yet
Posted 20 February 2007 - 03:31 PM
also ......
power lead with inline fuse which will require a simple red-to-positive / black-to-negative connection to your battery.
Tip : Taking the power direct from the battery means less chance of interference from your ignition & wipers, and you can have the CB on regardless of what position your ignition key is in.
does this mean I need to wire power cables all the way to the boot ?
yer i would run it direct off the battery as you dont get as much static noise, i had mine going to the cig lighter socket and that was ok though.
just if u run from the batt jus remember to turn the set off with the engine because your battery will last 10 mins with a cb plugged into it with no power from the alternator,
#77 lemmingzappa
lemmingzappa
    Tubby White Ninja!
  • 1,480 posts
Posted 20 February 2007 - 07:19 PM
cheers dude, and what about mounting at the front ?
#78 edd
edd
  • 94 posts
Posted 20 February 2007 - 11:57 PM
if you mounted at the front its going to be more permanent, and in my experiance they are prone to vandals bending them or snapping them clean off, or even worse seing a cb antenna (or mount if anttena is removable,) and breaking in to look for the rig to nick even if its been removed, i would just suggest a good mag mount, most cb antennas will be able to accept a mag mount base, but the bigger the antenna the bigger the mount has to be because it will fall over
you could on the other hand use a gutter mount but that will leave two marks on the paint where you lock the screws down into place to hold the mount on, go google and take a look for cb shops and look at the pics of mounts and you will see the good and bad points about them thats why i use a mag mount that cost 25 quid from tandy lol
im making a call 2mo about good mag mobile antennas i will post up my results 2mo.
i found a bood lid mount for minis, but same as a gutter mount damage will be caused on the inside of the boot but you could pad the out side so no damage is caused
http://www.4x4cb.com...cfm?itemID=1086 this will support most mobile antennas so i will find out the best to use with a mag mount and the best to use with this type of mount.
or this type of mount in your hole at the front http://www.4x4cb.com....cfm?itemID=717 and then you could remove your antenna wen not in use, again this will accept most mobile antennas,(the mount is permanet)
i think its goin to be personal preference on this one, but i will find out the best antenna
Edited by edd, 21 February 2007 - 12:03 AM.
#79 Big Man
Big Man
    Put your trousers on---You're Nicked!!
  • 1,002 posts
Posted 04 April 2007 - 08:58 AM
mounted my aerial on a bracket that is attathed to the second bolt in form the offside rear bumper. look discreet when aerial is not in it and when in looks ok, aerial is black which matches the exterior trim of the vehicle. Range at present is approx nine to ten miles reckon i can better that thought when I set it up using an SWR meter. Will post a pic when I find out how to do it.
Bracket is fashined out of a steel bicycle spanner and hammerited, it does not mtter as it cant be seen.
#80 lemmingzappa
lemmingzappa
    Tubby White Ninja!
  • 1,480 posts
Posted 04 April 2007 - 12:52 PM
kool thanks for the info, i'm keeping all of this in mind.
#81 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 04 April 2007 - 12:59 PM
Ive just buoght my cb from 4x4cb.com and i just got the magnetic airiel base.
Was going to get the gutter mounting BUT you have to make an "Earth" with it, meaning you have to scrape the paint awa to get a signal. You also have to do a SWA test (i think its aclled SWA, might be something else, basicalyl a teast to see where you will get the best reception).
If you need some help leave a message on the answerphone of 4x4cb.com they guy is AMAZINGLY helpful.
#82 LilacLilly
LilacLilly
  • 199 posts
  • Local Club: M.A.D MINI SOCIETY / ABERYSTWYTH
Posted 09 April 2007 - 06:10 PM
our 6 minis have all got CB's you need a licence depending on the type of CB used according to our local copper! if you think minis look strage with them i will post a pick of mine tonight!
#83 Silicon Skum
Silicon Skum
  • 743 posts
Posted 10 April 2007 - 12:46 AM
Only if it's significantly modified from standard, or it's using a diferent band (such as the AM bands or non UK frequencies), in which case you will then prolly require a HAM radio licence (certainly if its running on the non CB licenced frequencies). A standard CB no longer requires a licence for use. A "HAM" (radio amateur) licence, depending on licence class, allows the the use of modified radio transmitters and equiptment, Higher transmitting power levels, use of different comunication techniques, and also allows the use of a number of other frequency bands not accessable to the general public.
There are other radio tranceivers that are often refered to as "CB" radios, but are NOT actually CBs as they do not use the CB band, usually something like the radios used by security staff, workmen on buildings sites etc. These may or may not require a licence depending of the bands used and transmiting power.
But, as I said - a standard 'CB' radio does not require any form of licence now. :P
SS
#84 fatmini
fatmini
  • 735 posts
  • Local Club: no
Posted 10 April 2007 - 11:40 AM
what is the frequency range of the CB's and are they all now on fm ? or AM and FM ?
#85 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 10 April 2007 - 11:48 AM
a swa meter can be fitted in line to your aerial and will give an indication of the set ups performance.... i used to be into CB's about 15 years ago and i hada great book on tuning the aerial... basically, depending on the SWA reading, you need to alter the length of the aerial to its optimum.
#86 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 10 April 2007 - 11:59 AM
SWR Standing wave ratio :P
#87 biggav
biggav
  • 5,830 posts
Posted 10 April 2007 - 12:02 PM
no no no.....
Strong Weak or Rubbish!!!!!!!! :P
Breaker breaker!!!!!
#88 lemmingzappa
lemmingzappa
    Tubby White Ninja!
  • 1,480 posts
Posted 10 April 2007 - 12:27 PM
Does anyone have any pics of their cb units mounted inside their mini ?
#89 Silicon Skum
Silicon Skum
  • 743 posts
Posted 10 April 2007 - 01:53 PM
27Mhz band, 40 channels (additional 40 on the CEPT band - so 80 total), FM only, 4 watts MAX transmission output - for th UK.
I cant remember the exact frequency range for every channel, but a quick google (try "27/81 bandplan") should pull up the answers. :P
Only the FM band CB are legal in the UK, the older AM (American imports in the 70's - early 80's) are not part of the UK CB (Citizen Band) specification and can still land you in trouble for using them without apropriate licences to do so, but they are few and far between these days.
SS
#90 fatmini
fatmini
  • 735 posts
  • Local Club: no
Posted 10 April 2007 - 03:29 PM
CEPT band
sorry whats this mean ?
cheers for the info
