weber with spi?
Posted 04 January 2007 - 08:10 PM
can you fit a weber carb like this one
http://cgi.ebay.co.u...1QQcmdZViewItem
to an spi car? would you even want to? its a 94 mini 35 and i want it to go quicker!
if not what are my alternatives to get a similar performance boost?
Posted 04 January 2007 - 08:15 PM
Posted 04 January 2007 - 08:16 PM
Just go the usual tuning route.
Avoid cmas other than those for the injection, avoid 1.5 ratio rockers, avoid tunnel port heads. Make sure the injection system is working correctly.
and if your not bothered about loosing some top end speed, change the Final drive to a 3.44:1
Posted 04 January 2007 - 08:19 PM
Posted 04 January 2007 - 08:30 PM
Edited by nev_payne, 04 January 2007 - 08:30 PM.
Posted 04 January 2007 - 08:34 PM
That and 94 mini 35's are in fact Carb not SPi? Was the last editon to have said carb...
Not if its a 94 'M'
if its non cooper 94'L' its a carb
Posted 04 January 2007 - 08:35 PM
if u do fit it you will need to get a distributor too as the injection computer controls ignition timing!! (poss megajolt or a 123 dizzy)
if u want to go mental with a webber, etc then u need an older block (pre cat) to get round the emmissions laws!! and a box cut in the bulkhead, that swan neck manifold is a waste of time and bhp!
Posted 04 January 2007 - 08:37 PM
Not if its a 94 'M'
its a 94m, but not a cooper? this is confusing! i know sweet fa about all this, i just want to make it faster!
Posted 04 January 2007 - 08:40 PM
Posted 04 January 2007 - 08:51 PM
can u supply a picture of your engine bay at all??
Posted 04 January 2007 - 09:17 PM
And my theory is shot down in bits
Edited by Mini Sprocket, 04 January 2007 - 09:18 PM.
Posted 04 January 2007 - 09:29 PM
As I said Mini 35's as a model rather than as a year grouping were all carb'd. Bit of an odd one tho I have to agree.
Edited by nev_payne, 04 January 2007 - 09:31 PM.
Posted 04 January 2007 - 09:39 PM
Posted 04 January 2007 - 10:03 PM
Posted 04 January 2007 - 10:15 PM
i did wonder, because i saw pics of Spi and thought "thats not what mine looks like!"
so where would i get the correct stage 1 kit for it then? i'm talking part no.s here!!
and can someone explain the different types of carbs without confusing me any further?
