hi i have a mini 1000 with a two clock dash how easy is it to install a 3 clock dash and what extra gear will i need to set it up?
cheers
dash clocks
Grease_monkey1986
, Jan 05 2007 02:16 PM
5 replies to this topic
Posted 05 January 2007 - 02:16 PM
Posted 05 January 2007 - 02:21 PM
from memory you'll need, the 3 clock pod with circuit board, new clock mount as teh one you have now is too small and a couple of wires!
Posted 05 January 2007 - 02:55 PM
Someone once told me the wiring for the third clock is already there, its just a case of getting the new pod and plugging it in. Don't know how true this is but i will find out fairly soon.
Posted 05 January 2007 - 03:13 PM
cheers guys i thought as much. well you learn by doing so ill get stuck in and see what happens lol.
Posted 05 January 2007 - 03:19 PM
The wiring is there, I (eventually) found it. There is a little white wire with a black stripe down it for the rev counter on my 88/89 City.
Posted 06 January 2007 - 12:05 PM
not all minis had it in the loom, depends n the age but all after '84 should have it there. be carefull there are 2 types of 3 clock dash, the very early ones have 2 bullet connectors and 1 spade in the back of the rev counter not 1 of each and they are wired up differently. i think its original cooper and 1275 gt clocks that did that and there have been plenty different since then.
