If I am installing a new preverto clutch onto a verto engine...how important are the "A" marks?
Does the "A" on the pressure plate still need to be at the timing marks?
Does the "A" on the diaphram still need to be at the timing marks?
Does the 2 "A"'s just need to be lined up?
I'm only asking because I already torqued the flywheel and then went back and looked and was 1 hole off on the backing plate and it appears there is no way to rotate it behind the flywheel!!!
DOH................
Edited by Bill USN-1, 08 January 2007 - 06:59 PM.
