can select gear with stick but drive shafts go round???
Posted 10 January 2007 - 12:29 AM
Posted 10 January 2007 - 12:34 AM
Posted 10 January 2007 - 12:37 AM
http://www.theminifo...showtopic=38645
Posted 10 January 2007 - 12:41 AM
Once both driveshafts are in and one wheel is on the floor you shouldn't have a problem
Posted 10 January 2007 - 12:42 AM
Posted 10 January 2007 - 12:55 AM
Posted 10 January 2007 - 12:58 AM
Posted 10 January 2007 - 01:04 AM
also thats a nice looking little engine spec there. Two Hs2's hard to live with?
Posted 10 January 2007 - 03:32 AM
It's the way a dif works. It send power to the wheel with least grip.
It's more of an unfortunate side effect of having to have a diff really. The diff actually works by allowing the wheels to not shred the tyres and shatter the gearbox every time you go around a corner.
Posted 10 January 2007 - 08:52 AM
Best thing to do is get someone to put their foor on the brake.
Posted 10 January 2007 - 11:22 AM
ps, you wont tighten up the castle nut to the specified torque with only the car in gear, as all you'll end up doing it turning the engine over...
you could put a strong bar through the studs, (wheel off obviousy), the bar resting on the floor, and then do it up
Posted 10 January 2007 - 12:00 PM
Posted 10 January 2007 - 12:38 PM
