Hi,
How is the rubber mounting block attached to the subframe, mine came off on a bump on the way home from work tonight? Is it easy to fix, could do with fixing so i can drive to wk tomorrow:-) Couldn't see in haynes/search...
Cheers All,
Danny
HELP - Exhaust Fallen Off
Danny Mini 30
, Jan 10 2007 09:56 PM
3 replies to this topic
Posted 10 January 2007 - 09:56 PM
Posted 10 January 2007 - 10:02 PM
The forward mounting block is held by two screws which retain the steel baseplate of the mounting. The rear one is held by a nut which holds a stud projecting from it's plate. It is more likely that your mounting has sheared than simply fallen off, if so you need a new one.
Posted 10 January 2007 - 10:08 PM
yea i think that is what has happened, damn, could only see a flat metal plate when i looked under, rubber must have pulled off, damn, will have to be wire till payday then:=)
cheers dan, danny
Posted 11 January 2007 - 07:23 AM
dont worry , the new ones are only a couple of quid
