Hazards Help
15 replies to this topic
#1 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 12 January 2007 - 03:48 AM
My hazards are playing up, when I put the hazards on only the left side flahes like if I were indicating left. One problem that I know of is that one of the wires has rubbed on a bit of metal and has broke but I've tried joining the wires together and doesn't changed anything, its the top left wire if you look at the block with the 2 at the bottom and the grouped 4 at the top. Also I have to hold the switch in the middle for them to flash.
It's a 1980 Clubman Estate by the way.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 12 January 2007 - 08:33 AM
try replacing the switch
these seem to cause lots of problems
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 January 2007 - 06:06 PM
Available new from here in their warehouse clearance sale:-
Flasher Unit - Lucas Link
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 January 2007 - 06:59 PM
Changing the flasher unit won't help. If the left side is flashing, the unit is working (although they should be flashing very fast). I'm going to say try the switch too. Do the indicators work properly?
#5 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 13 January 2007 - 01:25 AM
im with them, change the switch, europa spares online shop sell them relatively cheap if minispares seems expensive!!
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 January 2007 - 09:34 AM
or swap with a friend with a mini to try it
#7 robson
robson
  • 798 posts
Posted 13 January 2007 - 01:48 PM
it cant be the switch if one side works. The switch will only have 1 output for the indicator circuit which will split later on, supplying the various bulbs. It wont have terminals for each bulb indivudually, so there must be a break in the circuit somewhere further down
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 January 2007 - 02:04 PM
The problem here is with the hazards, not the indicators. And it affects one side, not one bulb. Most likely culpret is definitely the hazards switch or its connector block, IF the indicators work properly on the right.
Edited by Dan, 13 January 2007 - 02:04 PM.
#9 fikus01
fikus01
  • 1,910 posts
Posted 13 January 2007 - 02:05 PM
yes it has seperate terminals, the switch is sided!! not for each bulb but for left and right.
#10 robson
robson
  • 798 posts
Posted 13 January 2007 - 02:07 PM
it does? seems like a weird way to do it. At least now i know, thanks ;)
#11 fikus01
fikus01
  • 1,910 posts
Posted 13 January 2007 - 02:09 PM
top 2 terminals cut out the indicators so u can use both at the same time, the bottom 4 are left inducators, right indicators, an input from the flasher relay and the other feeds the warning light in the switch!
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 January 2007 - 03:13 PM
It's the only way to do it. Hazard switches are always pretty complex unless the system is controlled by a body ECU. When you press the switch it has to connect both sides of the indicator circuit together which obviously can't be connected together normally. It also has to change over the power to the flasher unit from ignition only to constant (or activate a second flasher unit on earlier systems) and connect in the dash repeater, all at the same time.
Edited by Dan, 13 January 2007 - 03:13 PM.
#13 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 24 January 2007 - 11:02 PM
Cheers for the replies, tried another switch but no luck. Does anyone know what the feed for the right indicators is in the 4 terminals that are grouped together? Indicators work fine when hazards are off and blinker doesn't flash any faster when the hazard switch is on and left side is flashing.
Would have replied sooner but this is the first time I've been able to get on.
Another thing, my hazards only work with the ignition on. It's not supposed to be like that is it but it must have passed its MOT like that last year.
Edited by Lt-SilverDragon, 24 January 2007 - 11:19 PM.
#14 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 25 January 2007 - 12:08 AM
You have some major wiring issues there. Sounds like it's been botched in the past. Try following the haynes WD through starting with the hazard circuit. The hazard circuit does not run through any fuses in the fusebox, there is a line fuse typically behind the carb which feeds the hazard flasher, then outputs to the hazard switch, which switches out to the lamps. When the hazard switch is (on) it also disconnects the feed (separate circuit) to the indicator stalk from the indicator flasher unit.
In summary
Circuit 1 - Hazards
Battery > Line fuse > Hazard Flasher > Hazard Switch > Lamps (L&R)
Circuit 2 - Indicators
Battery > Fuse Box > Indicator Flasher > Hazard Switch > Indicator Switch > Selected L or R Lamps
#15 fikus01
fikus01
  • 1,910 posts
Posted 25 January 2007 - 02:29 AM
green/white is right, green/red is left as far as if i remember my mini wiring!! there is a join or 2 in that loom so it could be a break!
