what are the 2 yellow relays for in the engine bay?
Posted 12 January 2007 - 10:23 AM
Posted 12 January 2007 - 03:56 PM
for front spot,fogs indicators and alarm-The relays for the electrics appeared from about 1990 on and all single point injection cars and are colour coded for ease
mine could be redundant then. will have to check.
ta
Posted 12 January 2007 - 06:18 PM
Posted 12 January 2007 - 06:28 PM
Posted 12 January 2007 - 06:31 PM
Posted 12 January 2007 - 06:55 PM
Different cars had different numbers of relays fitted to that bracket, I think the basic two are for the cooling fan and Hazard changeover (but that last one might be inside the car, not too sure). Later cars had a single flasher unit and a relay to turn on the indicators instead of two flasher units. Injection and various options such as front fogs add more relays to the bracket.
Edited by Dan, 12 January 2007 - 06:57 PM.
Posted 12 January 2007 - 08:41 PM
Posted 12 January 2007 - 09:30 PM
Exact colour of wires and its tracer please
Edited by Mini Sprocket, 12 January 2007 - 09:31 PM.
Posted 12 January 2007 - 10:48 PM
Posted 12 January 2007 - 11:13 PM
Posted 13 January 2007 - 12:31 AM
Posted 13 January 2007 - 01:17 AM
Edited by fikus01, 13 January 2007 - 01:18 AM.
Posted 13 January 2007 - 10:34 AM
Posted 13 January 2007 - 01:43 PM
The dim-dip lighting system uses only one relay, the big pink one under the dash. It forces the dipped beam lamps to come on at 30% brigthness if the sidelights only are turned on and the ignition is on. That is all it does, nothing else. Your lights do work with the ignition off, honest.
I'm now pretty sure they are for indicators and cooling fan. The simple answer is of course to pull them out and see what doesn't work.
