what are the 2 yellow relays for in the engine bay?
24 replies to this topic
#16 robson
robson
  • 798 posts
Posted 13 January 2007 - 01:46 PM
while i have been rewiring parts of my car, i found out what the yellow relay on the right is, the ignition switch relay which feeds into the starter solenoid ;) Haynes can be confusing when you are working with parts from 2 wiring diagrams
#17 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 13 January 2007 - 02:07 PM
fek i was thinking the one on the left was the start one but thats on earlier cars when they first brought out the pre-engaged starter!
easiest thing if u tell us the wire colours i think.
#18 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 13 January 2007 - 03:09 PM
well, its puzzled me and haynes is no good. my loom has these 2 relays and its from 1992 british open classic (carb)
#19 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 January 2007 - 03:18 PM
Like Fikus I though the starter relay was on the left, by the brake servo. It was there on earlier looms and I suppose I just thought they'd leave it there as it seems a bit odd to move it further away from what it's controlling and what it's controlled by. Is your car injection Robson? As they have a seperate sub-loom for the injection systems and the relay you are talking about could be the immobiliser relay since the alarm ECU is right behind that relay bracket.
#20 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 January 2007 - 07:00 PM
Injection have two relays on the bulkhead, one on the left is the Lambda sensor heater , the one on the right is the electric fan.
The Lambda sensor heater relay is part of the engine loom, the fan relay is part of the front 'body' loom.
Just looking for the info so i'll be posting back in a minut
#21 robson
robson
  • 798 posts
Posted 13 January 2007 - 07:11 PM
94 carb, havnt identified the relay by the servo yet but im certain the yellow relay to the right of the group of 2, is the starter relay
#22 Sprocket
Sprocket
  • 7,266 posts
Posted 13 January 2007 - 07:36 PM
Nope. Need wire colours.
The workshop manual I have is missing the connector location page.
#23 fikus01
fikus01
  • 1,910 posts
Posted 14 January 2007 - 02:21 AM
yep wire colours, there is a start relay on my mates 93 k plate mayfair, and its on the right by the wiper motor!! but there are 3 relays there!! i think rover must have had a basic plan and met the guys do their own thing!
#24 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 14 January 2007 - 09:42 AM
Here you go, I think the only reason these yellow ones are are used is for ignition OFF. They turn the fan off when the key is turned to the off position and lights etc.
And the dim dip
My lights etc work fine without these.
#25 fikus01
fikus01
  • 1,910 posts
Posted 14 January 2007 - 03:55 PM
the one on the right is the start relay, white/pink is faded white/red from the starter switch, brown is permanent live i believe and brown/red goes to the solenoid on the starter motor.
from memory the left hand one is the indicators disconnect when the ignition is off.
the dim dip relay isnt essential, all works without it i believe, just u wont have very good sidelights at the front as is switches in the resistor thats stashed on the crossmember behind ur rad that lights up the headlights half way when the ignition is on. not sure if its a legal requirment. all modern cars have them so look into that.
Edited by fikus01, 14 January 2007 - 03:56 PM.
