after about 20mins of driving sometimes my indicators stop working, but my hazzards still work. whenn i stop the car and say go out later there back! whats up with that!?
faulty indicators
Grease_monkey1986
, Jan 15 2007 06:35 PM
4 replies to this topic
Posted 15 January 2007 - 06:35 PM
Posted 15 January 2007 - 06:57 PM
Relays On It's Way Out.after about 20mins of driving sometimes my indicators stop working, but my hazzards still work. whenn i stop the car and say go out later there back! whats up with that!?
Posted 15 January 2007 - 08:23 PM
or the hazard switch is, or both!! does turning on the hazards and back off again start the indoicators working again?
Posted 16 January 2007 - 12:19 AM
nope i tried putting the hazzards on while the indicators had failed and it didnt help. where is the relay located and which 1 is it? cheers guys ur a massive help!!
Posted 16 January 2007 - 12:24 AM
What type of dash clocks do you have? If it's the central speedo then you'll find the indicator and hazard warning flasher units mounted next to each other, just to the left of the wiper motor (on the engine bulkhead).
If its the later Clubman style 2 pack instruments then the indicator flasher unit will be mounted behind the instrument pod. But you can just reach it by sticking your hand up and under the parcel shelf and rooting around. It'll be mounted on a little bracket and have 2 spade connectors, unless it's fallen off?
I doubt you'd have a relay on a pre injection Mini like yours?
