Hi Guys
We are currently refurbing the gearbox and I have been looking through different suppliers.
Looking at the Mainshaft, I have found a price difference that is quite considerable.
Has anyone purchased either (or both) and would be able to shed some light on the reason for the vast difference?
http://www.minispare....aspx?pid=32578
http://www.minisport...ft-product.html
Thankyou
David
Third Motion Shaft
nomininolife
, Jan 15 2007 07:09 PM
6 replies to this topic
Posted 15 January 2007 - 07:09 PM
Posted 15 January 2007 - 07:34 PM
and the shout heard from on high in unison was......................."GUESSWORKS"
Posted 15 January 2007 - 07:38 PM
"guessworks!"
damn, out of time again.
Posted 15 January 2007 - 07:53 PM
If you're after a new one, Min-its had some going for a song,
there are actually 3 different 3rd motion shafts for the 4 synchro,
One for the A series,
and two for the A+,
firstly you need to get the right one for the gearbox, either A or A+, this is dictated by the nose bearing A series 14mm and A+ 18mm....
secondly there were two A+ shafts with different threads on the end for the pinion retaining nut.. can't remember the sizes of the top of my head...
What's wrong with the one you have, as it's realy only necessary to change the third motion shaft if the nose bearing has disintegrated and taken the shaft with it, which usually means the input (1st motion) shaft is also fubar.
and two for the A+,
Posted 15 January 2007 - 08:10 PM
Hi Guessworks
I was just looking, as the layshaft is showing wear, a bit like a rocker shaft in colouring and preparing for the worst. It is an A+.
David
David
Posted 15 January 2007 - 08:16 PM
The colour of it imaterial, if there's no breakup, then most of the time you're better to continue to use it.... same with layshafts.....
Posted 15 January 2007 - 08:24 PM
Thanks for the advice.
David
David
