speedo problems
dying2live06
, Jan 15 2007 07:34 PM
9 replies to this topic
Posted 15 January 2007 - 07:34 PM
ok firstly i have some mechanical knowlege
ive taken the old speedo cable and put a new 1 on and b4 ne1 asks its connected
whats the likelyhood thats its the speedo its self my car is on a G plate
and i really dont hope the problems at the other end i guessing its engine drop time if it is ?? can ne1 help ???
Posted 15 January 2007 - 07:37 PM
errm....so whats the problem?
Posted 15 January 2007 - 07:40 PM
sorry the speedo still isnt workin ??
by the way its been i long day
Posted 15 January 2007 - 07:41 PM
What I would do personally is:
Detach the cable from the speedo head, put it somewhere I can see the inner cable and run the engine.
If it turns you have drive and it is a problem with the head, if not then it is fun time.
David
David
Posted 15 January 2007 - 07:47 PM
also right cable for speedo ( should have a white plasticy end with a metal insert )
Way to test a speedo, stick a match in the back and twist, if needle flicks then ok...
Posted 15 January 2007 - 07:58 PM
yep right speedo and good thinkin tks guys !!
Posted 15 January 2007 - 08:12 PM
How on earth did you get your arms down there to untwist the cable off? I tried laying under the car and could only get 2 fingers on it from that angle and 2 from on top. My arms are all scratched up from the forcing of skin to mesh with the small wires and connectors for the hoses.
Posted 15 January 2007 - 08:15 PM
taking the timing cover off makes it damn easy to do.
Posted 15 January 2007 - 11:41 PM
There's a hole in the subframe at the rear you can just get your hand in.
Posted 16 January 2007 - 01:49 AM
if u have skinny arms u can get ur arm down tha back and do it from the top getting it up on some ramps is the best option i have found in car, failing that fit it before the engine gets put in.
