starting a car on minium wiring
Posted 15 January 2007 - 08:29 PM
it is my mates and he wants to start the engine to prove it works(it did before the birds nest of wiring was ripped out)
i think it needs about three wires to the solenoid and dizzy but not entirely sure.
Can anyone help?
cheers
Posted 15 January 2007 - 09:05 PM
Posted 15 January 2007 - 09:09 PM
Run it from the battery post side of the solenoid to the + side of the coil. The - side of the coil goes to the distr.
If it has a ballast then you should hook the jumper to the post of the ballast farthest away from the coil.
But it will run either way.
Then just make sure it's in neutral and hit the button on the solenoid or jump it from the batt side to the small terminal.
If you hold the coil wire close to the block while cranking you will know if there is spark!!
Posted 15 January 2007 - 09:29 PM
Posted 15 January 2007 - 10:06 PM
Posted 09 February 2007 - 06:06 PM
All it really takes is 1 wire with clips on each end.
Whats a ballast
honest???
Posted 09 February 2007 - 06:51 PM
I'm sure all these people are really Jammy in disguise....
