hi guys some help please!??
Posted 22 January 2007 - 11:29 PM
ive recently just respayed my bonnet i sanded it down with 600 untill i was happy with the results then i filler primed the stone chips and sanded again with a block i then applied sevral coats of halfords white primer waited untill this dried and then i rubbed down with 1500 grit to get rid of orange peel i then sprayed my colour (halfords rover electric blue from a rattle can) did many coats and was amazed with the results i was about to apply my laquer a week later only to find lots of little bubbles surfacing from the paint!!!! was ver angry and i sanded it down again to reveal spots of white primer and bare metal in places i then reapplyed the white primer and a few hours later i came back to it to find the primer was all cracked and it just carrys on cracking every time you spray it!!!!! any ideas what this is!?? and any ideas on how to rectify the problem!??
many thanks for any help phil. :'(
Posted 23 January 2007 - 12:07 PM
Also what temperature did you spray at?... if it's too cold the paint will crack.
Have you got any pictures of the bonnet we could see?
Posted 24 January 2007 - 10:11 PM
yea the bonnet was sprayed in the cold i have no where thats warm to spray and the cars gotta be on the road by march!
we also found that the paint dosent crack if you cover it with the yellow acrilic primer what do you suggest i do nitromors the bonnet and start again or cover with yellow primer and respray?
this is a poor pic but its all ive got at the moment.
cheers for the help! phil.
Posted 25 January 2007 - 03:35 AM
[/quote]
Is there any filler or stopper under that bit on the first picture?
I had a similar problem applying primer over stopper.
Posted 25 January 2007 - 10:21 AM
erm i cant remember for sure but we found that if you spray it with the yellow filler acrylic primer then it dosent crack
cheers for any halp again phil
Posted 25 January 2007 - 10:06 PM
Posted 25 January 2007 - 11:22 PM
Its like fine filler cellulose putty for filling small scratches etcwhats stopper???
cheers for any halp again phil![]()
Posted 29 January 2007 - 08:47 PM
all the best guys phil
Posted 29 January 2007 - 10:21 PM
hey guys thanks for the help well this weekend i sprayed the whole bonnet with filler primer the yellow stuff! hehe a 50:50 mix with thinners it now looks like this! ill have to wait till next weekend to spray it but so far so good. hehe
looks sealed well enough now. dry flat it with 320 grit before you primer it. allow to dry. dry flat it agaoin. degrease. if there are any break thrrough's dust a little primer over the area, leave for a few minutes and then start applying colour coats, in even passes. allow to dry between coats and tack off with a tack rag. this removes any debris from the paint. after the final layer of colour, alllow 15 minutes to dry, give a final tack off and apply the clear coat.
Posted 30 January 2007 - 11:32 PM
oh my god!! im so so so so lost sorry to say i barley understood those technical terms! hehe
whats a tack rag? 320 grit!!! ive been using 1200- 1500!!?? whats flatting?? only mist with primer!? dont i cover it in primer? do i then have to sand the primer down?? tack off in between every single coat? dry flating whats this? how long do i leave it in between coats?
many thanks for any help im really relying on you guys! thanks again phil.
Edited by phils sprite, 30 January 2007 - 11:36 PM.
Posted 30 January 2007 - 11:43 PM
thanks so much you guys are ledgens!
Posted 31 January 2007 - 11:53 AM
A tack rag is a piece of 'tacky' cloth, you use this to after prepping your panel to get rid of the last flittle bits of dust that you cna't wipe off, it ensures a dust free surface for paint to adhere to. You simply wipe it over the panel...whats a tack rag?
As you know, Wet and dry come in differnt grades.... the higher the number.. the finer the grade. 320-800grit is for keying a surface ready for paint, 1200-1500 are for finishing a paint job which leads to....320 grit!!! ive been using 1200- 1500!!??
Flatting is where you use a Fine grade (1200) sheet of wet and dry to 'flat' out any mior imperfections before polishing you freshly painted panel up. flatting back ensures a flat consistent surface of paint, making polishing a dream!Flatting
The panel should be covered in primer,.. about 2-3 coats would do, then 'Flat' it back with 600-800 grit. This gives the Top coats (colour coats) a good surface to adhere to.Only mist with primer!? dont i cover it in primer?
This is where you use 'wet and dry' paper withough a lubricant. Generally I wet sand paint with warm water, the water stops dust going everywhere and acts as a nice lubricant, stopping scratches.Dry flatting, what's this?
whatever the manufacturer specifies on the back of the paint can matehow long do i leave it in between coats?
As for roller painting, read my project thread in the painting section to answer all questions.
CooperShaz has written a step by step 'how-to' spray your car guide, it's a sticky thread at the top of the painting section. read it and learn.
Posted 31 January 2007 - 01:57 PM
well ive bought a gloss mini roller from diy shop and im gona give it ago! also bought an electric buffer so paint should be looking good soon!!!
thanks again for all your help! phil.
Posted 31 January 2007 - 01:59 PM
Posted 31 January 2007 - 04:37 PM
