is this suitable to spray a car with?
Posted 23 January 2007 - 07:26 PM
Posted 23 January 2007 - 08:37 PM
I just bought 1 litre of basecoat, 1 litre of primer, 5 litres of 2K thinners, affiliated hardner and laquer and that cost £115.00. That is to paint four panels NOT the whole car.If the result is cr** by using a c**p gun you waste the material money PLUS hours of time getting all that paint off.
Remember the preparation takes the time, there is not short cuts for us amateur paint boys. The professionals have £000's tied up in paint booths etc etc. & therefore, rightly so, charge between £100 - £130 to paint ONE panel. So your only chance of getting a decent finish is using the pukka gear. Plus a horrible paint finish will wreck the value of your car
I am sure woody will add to this ( as he clearly is a professional) and hopefully will agree with me, as he has advised me through my first 2K experience.
Edited by webweavers, 23 January 2007 - 08:47 PM.
Posted 23 January 2007 - 08:40 PM
Posted 23 January 2007 - 11:19 PM
I once sprayed my suzuki SC100 (its a little car) with a tiny compressor and low-pressure spray gun in an old shed , and after lots and lots of flating and buffing it looked great (this was in the good old days with cellulose)
but a good job can be done if the prep work is spot on without spending a fortune (but forget the airless sprayers!)
Posted 24 January 2007 - 01:45 AM
Would I beable to use my current compressor and a Water trap, With a Spray gun?
Also, Primer. Is that applied via the air-brush, or via Rattle can?
<|ben|>
Posted 02 February 2007 - 11:49 PM
as long as u use a water trap and that your compressor will allow you to spray continuously at 2 bar it should be fine using a hvlp gravity fed gun. primer is also sprayed on in this way. rattle cans are a bit pissy and brushing it on it rough and very messyIve got a compressor at my garage. I was wondering If I could use this to spray with. Or are Spraying compressors "Special" compressors.
<|ben|>
