Identifying pushrods & rocker assembly's
Posted 25 January 2007 - 11:29 AM
1/. How can I identify which pushrods are for what engine?
2/. How can I identify rocker assembly's?
I need to know for buying the above for my MG metro 1275 engine.
Thanks.
Posted 25 January 2007 - 11:42 AM
Edited by Big_Adam, 25 January 2007 - 11:43 AM.
Posted 25 January 2007 - 11:50 AM
Posted 25 January 2007 - 11:51 AM
Posted 25 January 2007 - 12:09 PM
Problem though, how can I compare shorter and longer ones if they are all the same size? Then I wouldn't know if the ones I am holding are "long" or "short"...
Does that make sense?
Posted 25 January 2007 - 12:53 PM
Hold on. I'll pop to my garage and measure up a push rod for you. 998 one. 2 sec.
*tic tock*
8 and 1/2 inch. For 998 just about.
Edited by Big_Adam, 25 January 2007 - 12:56 PM.
Posted 25 January 2007 - 12:55 PM
If i could know the size of just one, that would be awesome. Cheers.
There's no difference between A-series, A+?
Posted 25 January 2007 - 01:56 PM
Posted 25 January 2007 - 02:04 PM
Thanks!!
Posted 27 February 2007 - 01:00 PM
However, just out of interest I put them in the block and they seemed to be the right length. I've since put all of them in, and put the head on with the rockers and everything lines up right.
So, the push rods I am using are 8.5 inches long and fit perfectly in my MG Metro engine.
Posted 27 February 2007 - 01:39 PM
When i put a 1275 head on my 998 i didn't think there was a difference in them, so i used the 1275 'rods. It was only after the motor went boom that i found out 998 'rods are actually shorter. Tho i still can't tell the difference, they look the same to me.
Edited by JetBLICK, 27 February 2007 - 01:39 PM.
Posted 27 February 2007 - 01:48 PM
Posted 27 February 2007 - 02:03 PM
Posted 27 February 2007 - 02:05 PM
Damn there isn't a RESPEKT smiley so that'll do!!
Posted 27 February 2007 - 04:49 PM
Awesome, cool. Thanks guys!
Well just to throw a wrench in this since I just swapped from a 1098 to a 1275...the 1275 pushrods are longer.
It's a big deal if you try to use the 998 push rod in a 1275. The adjuster screw will have to be screwed down to almost the end. This changes the pivot point and puts more stress on the rocker.
On my 1275 the pushrod would almost hit the side of the hole also.
I found some good info in the Visard book while researching this on my motor.
Now going the other way and installing the 1275 pushrods in a 998/1098...there may not be enough room to back the screw out for the adjustment.
I recommend matching the pushrod to the motor!!
