Crank woodruff key
4 replies to this topic
#1 Big_Adam
Big_Adam
  • 7,435 posts
Posted 25 January 2007 - 03:28 PM
Evening,
Well got my order of parts (ball joint bits, few little buit for the rad and timing chain) for El Gordo and I'm off to go stip her down today then build her back up tommrow. When I last did the timing chan tho I could not get the woodruff key out of the crank.
How on earth do you do it?!?
It baffles me so.
Ta chaps/lady's/alien life forms of unknown gender/ghosts/asexual creatures.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 January 2007 - 03:37 PM
You should not need to remove the key, the cog should just slide over it..
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 25 January 2007 - 06:21 PM
Duplex needs shimming.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 January 2007 - 06:33 PM
Ah..
Well in that case... when the timing cog is off, gently tap one end with a hammer on the top and it should pop out the other.. ( using a fine pointed screwdriver to lever it can also help )
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 25 January 2007 - 06:43 PM
did try that. not alot of room to swing a hammer as the engine is still in the car. Oh well I'll give it another try.
