Clutch Pedal and Clevis
2 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 25 January 2007 - 08:11 PM
Hi, I have recently had a clutch problem where my mini is crunching badly when trying to select 1st or reverse gear. I have a pre-verto clutch. I just noticed (being advised by Mini doc DKLawson) to inspect the clevis area of the master cylinder.
I have discovered that I am able to lifet the clutch pedal by approx 10mm from its current rest position and the clevis doesn't move at all. Is this right or do I need to correct this?
Doug, you may see this new thread...just worried about it thats all.
John
#2 lunchboy
lunchboy
  • 19 posts
Posted 26 January 2007 - 03:46 AM
John
Check wear at slave cylinder push rod and clevis pin.Also the ball end on the clutch lever rod and mating hole in the clutch throw out plunger. 10 mm wear equates to 20 mm less travel to release the clutch.
#3 mk=john
mk=john
  • 1,167 posts
Posted 26 January 2007 - 02:00 PM
Hi
I have made a not of that, and will be going to minispares today to get all the clevis pins, throwout plunger, release bearing, clutch arm, push rod.
I think if all play was eliminated I think almost an inch of travel will be gained in the clutch pedal.
The clutch pedal itself has a slightly elongated hole, and I hope to get a new clutch pedal. I am not sure if Minispares will sell that for a mk1 mini.
John
