Starting problem after putting another engine in
Posted 28 January 2007 - 10:33 PM
I thought that maybe I should start another thread as I no longer have the problems mentioned in the title and was worried that people wouldn't read it as the problem was solved.
The Thread is: http://www.theminifo...x...40451&st=15
Please help in any way you can think of.
Posted 28 January 2007 - 10:49 PM
David
Posted 28 January 2007 - 11:03 PM
TBO I haven't actually checked if the plugs are wet or not but I definatly will do.Following on from your last post, are the plugs wet? and have you done a compression test?
David
How can I do a compression test?
Posted 28 January 2007 - 11:31 PM
to check remove the rocker cover, if both srings are up then you are on compression, if one is down your on exhaust.
otto's cycle induction comression power exhaust.
then check your leads again. also the firing order going the right way, if your not sure, best way to check is to remove the dizzy cap and turn the engine over seeing which way it turns.
see how you get on
Posted 28 January 2007 - 11:54 PM
Ok I will have a look again. I lined up the notch on the bottom wheel below the alternator with the top mark on the engine as I thought this is supposed to be TDC, Also I tried to get a scewdriver down the hole where the spark plug goes and it wouldn't go down at all, I then put the dizzy on like this and it only went on one way and wouldn't go in any other way. Is this right?ok ive had a quick check through, when you had the timing set, how did you know you were on compression stroke for no 1.
see how you get on
I take it the engine turns anti clockwise as I put the leads on in this order
Posted 29 January 2007 - 06:14 PM
Does this sound right to you?
Posted 30 January 2007 - 03:36 PM
What could this be? Why is the fuel not getting into the head?
I thought maybe the piston on the dashpot could be sticking or something and not allowing any fuel in, but then the fuel did drain down that I put in the air filter manifold so it can't be surely.
What do you guys think?
