Hi
i recentlly had my throttle cable snap, so on the path to fixing it i noticed that when i rev the engine smoke comes out of the heater hose where the heater adjustment is, i know my dad changed something so the engine heated up quicker, was just checking this isn't something major...
Jimmy
smoke!
mayfairjimmy
, Jan 30 2007 10:28 AM
4 replies to this topic
Posted 30 January 2007 - 10:28 AM
Posted 30 January 2007 - 11:37 AM
Is it definately smoke? As opposed to Steam? What did your dad do and if it is smoke, i would say it was something potentially major.
Posted 30 January 2007 - 11:45 AM
i'm guessing it's smoke it only happens whe you rev the engine up, i think he put a hose from the heater to the inlet manifold i can get a picture up later this evening
Posted 30 January 2007 - 11:48 AM
You would smell smoke! Its probably just steam, there could be a leak under load onto the exhaust manifold perhaps. But get your head under the bonnet when running and check for any water leaks or anything that maybe burning..
Posted 30 January 2007 - 12:24 PM
the Y piece manifold is loose i have a DTM exhaust and it got ripped of by sppeed bumps at college and since it has never wanted to stay tight i put aluminium sleeves on the Y piece to tighten the clamps but it is still loose would this cause this smoke? and there is a minor leak in my rad in the bottom back corner
