Quaife ATB
15 replies to this topic
#1 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 02:40 PM
I've just got off the phone to Quaife, who explained to me that you don't need anything else from them to use one of their ATB diffs. So you can use standard gears, standard crownwheel, standard outputs etc. You just strip the box, unbolt the crownwheel from your standard diff and bolt it to the Quaife item then put it all back together again!
#2 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 31 January 2007 - 02:52 PM
I thought it would have been like that when they say its for a production car.
So are you going to get one?
#3 ed4ran
ed4ran
  • 2,849 posts
Posted 31 January 2007 - 02:53 PM
and are you going to get them to make your driveshafts as well?
#4 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 03:03 PM
Erm, I've thought about the ATB, but was really put off when someone said you had to use a Quaife crownwheel and outputs! So last week I bought a Honda box with LSD for £360.
As for driveshafts, not sure yet. Was thinking about contacting Carl Austin about that. Hmmmm, Titianium! :w00t: Doubt my budget will stretch that far though. You got any leads on who can make driveshafts?
#5 ed4ran
ed4ran
  • 2,849 posts
Posted 31 January 2007 - 04:02 PM
Allspeed as far as i know they make there own, (approx £400)
Quaife, £500 for a pair.
I guess most engineers should be able to make you some if you can take some youve welded that they can measure.
#6 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 04:06 PM
Yea, as I thought, I was thinking about getting the Allspeed ones, as I believe they suit standard mini track, which my Vtec should have! Guess it depends on the placement of the engine too though. Want them to be one peice though, just don't trust welded ones, and think they'd be heavier than one peice.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 31 January 2007 - 04:56 PM
Think it may just be worth pointing out, just if no-ones reading the forum section.... the MINI Gearbox ATB does need n LSD style machined crownwheel, and output shafts too.... well that's if their technical drawing is correct :w00t:
Tech Drawing Mini ATB
#8 Bounce
Bounce
  • 2,197 posts
Posted 31 January 2007 - 05:08 PM
Did any of the B series Hondas come with an LSD as standard?
And where are you finding these LSD 'boxes????
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 31 January 2007 - 05:11 PM
Meh, I know it's just me being pedantic, but I hate drawings with errors on them, they can't even spell 'original'!!!!
#10 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 05:24 PM
Yes, The Integra Type Rs, and certain Jap Sir's I believe. It may of been an optional extra as well, but not sure on that. It will have LSD stamped on the gearbox casing.
#11 Bounce
Bounce
  • 2,197 posts
Posted 31 January 2007 - 05:41 PM
Cheers mate
#12 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 05:45 PM
I *may* have a 2nd LSD box soon, so if you want one I'll let you know.
#13 Bounce
Bounce
  • 2,197 posts
Posted 31 January 2007 - 05:48 PM
If I want one you'll tell me????
#14 Jammy
Jammy
  • 25,397 posts
Posted 06 February 2007 - 11:10 AM
Following on from this, CRX forums are trying to sort out a group buy of the Quaife ATB.
Linky
BounceL: Have a look in the Bits for Sale section on there, theres a couple of LSD boxes I believe.
#15 Bounce
Bounce
  • 2,197 posts
Posted 06 February 2007 - 01:12 PM
Ill keep an eye on that as well. Have you got rid of that spare LSD 'box yet??
