Top Arm Piviot Removal.
Posted 02 February 2007 - 02:25 PM
Getting to do my knucle joints and need to get the top arm out.....just it's stuck. Turns....okay. Nice free moval of the arm itself just can't get the damn bit out.
Any ideas?
Ta.
Posted 02 February 2007 - 02:32 PM
Posted 02 February 2007 - 02:35 PM
Yo,
Any ideas?
Ta.
i've just removed mine, you have to drift the pin from the rear of the subframe as it can only come out one way.remember to remove the 11mm bolts which hold it in(there is two going through a plate which holds it all in place) on the front first otherwise it won't come out.the top arm should then come out easily(easier than the knuckle joint!)hope this helps.
by the way use rubber mallet as to not damage the thread,as i did'nt.
Posted 02 February 2007 - 03:01 PM
as said above, did u remove the holding plate with the two small bolts, by the way its not 11, but imperial 7/16 or something like that
Posted 02 February 2007 - 03:59 PM
ah.
Posted 02 February 2007 - 04:01 PM
holding a plate that secures the shaft in the subframe
Posted 02 February 2007 - 04:06 PM
yay my back hurts!
Thats all I'm doing today then. Got the arm socking in a tub of sprint and I intend to get a toothbrush later and scrub it it. Get the rest of the cup out too.
On a diffrent note......should my cone things be full of water?
Posted 02 February 2007 - 04:11 PM
mine passager side one was full of water too when I changed my cones
Posted 02 February 2007 - 04:24 PM
yay it's out.
You know what Adam, it's great to see that you are gaining confidence with fixing your mini and getting help from other forumers! Well done!
Now you've just gotta put it back together!
Posted 02 February 2007 - 07:25 PM
mine came out very easy, but what a pain to put it back
7/16 and 11mm are basically same size,either one will work fine.just a quick question to go with big adams-how can i remove the roller bearings in the top arm?i've tried knocking them out with a long drift with no luck,what about heating them up with oxycetolyne torch?or is that a bit excessive!.
Posted 02 February 2007 - 08:55 PM
Posted 03 February 2007 - 11:47 AM
We clamped the arm in a vice, then used a modified drift, with parts of the edge grinded, so you can get more of an angle on the bearing! if it keeps jumping off, pur a drift in from one side, then use a bar/wood/something, to put in the other side, to brace the drift onto the bearing, so when you hit it it doesnt come off!
Dave
Posted 03 February 2007 - 04:57 PM
Posted 03 March 2007 - 09:29 PM
does anyone have any tricks for getting them out or know where can i find a tool to do them?
any help appreciated
James
Posted 04 March 2007 - 09:52 AM
