hi my windscreen washer jets aren't spraying water. i can hear the motor working and the resevoir is fiull to brim with water, but nothing comes out. some one plz help
thanks
waher jets not working!
MINI jon
, Feb 03 2007 06:51 PM
3 replies to this topic
Posted 03 February 2007 - 06:51 PM
Posted 03 February 2007 - 06:52 PM
try to see if the pipe from the reservior to the motor is clogged or no. also check the other pipes then
Posted 03 February 2007 - 07:14 PM
It may also be the actual jets that are blocked. Try unblocking them with a needle or a pin.
But first remove a pipe from the back of one of the jets, to see if the pipe is clear.
Edited by nomininolife, 03 February 2007 - 07:16 PM.
Posted 03 February 2007 - 09:57 PM
mines poo too!
i fitted the doulbe jets to mine and the pressure which was goin through one hole now is spread over the two holes and as you can tell isnt much cop now!
have they worked b4?
Edited by ginigwunkle, 03 February 2007 - 09:57 PM.
