Rust :(
3 replies to this topic
#1 day101
day101
  • 610 posts
  • Local Club: Dont have one:(
Posted 06 February 2007 - 04:22 PM
Right got a bit coming round the window screen and also round the front at the bottom of the lights, i can take the window screen out and sand it down and fill it all but the thing is about spraying the front end? urm i dont know what to do about that if i should give it ago my self or get some one else to do it. was also thinking about molding in the archs to the body work.
Any Advice :'(
#2 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 08 February 2007 - 03:14 PM
Do a quick search on POR15... fantastic stuff for rust treatment.
There is also a painting guide above which is well worth reading..
As for moulding the arches to the body, they WILL crack over time..
and then it is a pain in the ass to fix..
On the flip side it can look good..
Have blended quite a few, but tend to advise not to, once it cracks it spoils the look of the car..
just my 2p worth
#3 sillyface
sillyface
  • 51 posts
Posted 16 February 2007 - 02:02 PM
I sprayed the front end under the lights myself.
As it's not a large area like a flat door panel which can show a bad spray job, a bit of amateur spraying is good enough in my experience and blends in quiet well.
#4 Monstrous
Monstrous
  • 889 posts
Posted 16 February 2007 - 05:46 PM
I had about an inch diameter rust hole on my scuttle under the screen so i knocked all the rust out with a screwdriver and sanded it all down to bare metal about 2 cm's around the hole, fixed some alu mesh underneath the whole and filled it in. and using the paint guide and some help from cooper shaz i have a brand new looking scuttle, it turned out so well im thinking of respraying the whole outside of the car eventually
just take your time and do a bit of research
