Rebuilding My Stage 6 998!
10 replies to this topic
#1 Sammy D
Sammy D
  • 977 posts
Posted 09 February 2007 - 12:10 AM
Just bought a Slark modified 12G295 head with 29mm x 35mm valves, brass valve guides, double valve springs and it's all smooth inside. Anyway, thats bigger than stage 5, thats like stage 6.. Warp speed cap'n.
Also bought a 998 block, pocketed to fit the head.
I have a spare standard 998 lump here which I will be using for basic parts, although, I'll be needing some other stuff with that crazy head.
So I plan to get;
Straight cut drop gears, don't know what ratio yet?
Some sort of high lift cam to go with that head, maybe a 266?
Re grind the crank (maybe)
New pistons (maybe) not actually sure on the bore size, it might even be 1048
Different rockers, what ratio?
Probably just a single HS4 SU, I do have a spare though so could run twin HS4s, might be too much fueling tho?
Problems;
I THINK a piston has exploded in the first cylinder. It is slightly scored down the bore, the head has small imperfections (like someone has dropped it on gravel) where I presume the piston shrapnel has hit it, and the head between the bores has been re-welded by Slarks and skimmed.
Therefore, I think I will need a rebore, or at least an Hone. What do you think?
Basically, is anyone good at working out the ratios I need?!
Sam
Edited by Sammy D, 09 February 2007 - 12:12 AM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 09 February 2007 - 12:41 AM
Rockers,
1.3 is what you want, any more on a little engine and theirs too much overlap.
On the carb, many will suggest the equivalently HIF car (think its 34) but can I also suggest sorting the car out. Halfing the spindle and screws. I'll do it if you want.
#3 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 09 February 2007 - 12:48 AM
Sounds brilliant an' all - but do you know you don't need a pocketed block for you're head?? :angel:
#4 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 09 February 2007 - 12:56 AM
You need to pocket if using a 940 head, and to be honest, if the engine is a "stage 6" then this would be the head of choice... as stg4> uses the 1275 head, due to being able to have 37/38mm inlet valves....
For example... imgine a 998 with a 286 cam, with a 38mm inlet and a 32mm exharst!
MASSSIIIVVVVEEEE POWER - eh Jet blick :angel:
#5 Sammy D
Sammy D
  • 977 posts
I do, the valves are actually HUGE!
#6 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 09 February 2007 - 01:00 AM
29mm inlet.... thats the same size as the exhrast valve on a 940 head :angel:
honestly mate, get a 12g940 head!!
#7 Sammy D
Sammy D
  • 977 posts
Posted 09 February 2007 - 01:02 AM
My Inlets are 35mm! Exhausts are 29 on this head too.
Read the first thread again carefully :angel:
Anyway, back to the thread..
Highlift cam and 1.3 rockers?
Edited by Sammy D, 09 February 2007 - 01:03 AM.
#8 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 09 February 2007 - 01:04 AM
Even so, the 940 head is less resrited over the cooper head...
but still I have NEVER heard of a stage 6 engine... thought 5 was the highest, as that full out race engine...
#9 Sammy D
Sammy D
  • 977 posts
Posted 09 February 2007 - 01:08 AM
So did I, this is just different. Kind of stage 5+ :S
This heas has pretty much been modified to 940 with a few extra bits.
#10 JetBLICK
JetBLICK
  • 1,222 posts
Posted 09 February 2007 - 01:18 AM
Fair nuff then :w00t:
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2007 - 02:22 AM
Hmmm.
Anyway..
Get some of the new +100 pistons from Mini Spares and give them a try. Might be able to loose the pockets then too depending how much of these valves actually are a problem. I like forged Cooper S rockers on a thick walled shaft. You might be able to make use of a bigger carb than usual for the small block with this engine, especially if you do go +100. Maybe a single 1.75. I'd still stick with a Freeflow exhaust manifold over an LCB though.
Ignore the 'Stages of tune' by the way. It's a load of rubbish. Oh and two normal HS4s doesn't make a pair. You need a left and a right, like with shoes.
Edited by Dan, 09 February 2007 - 02:23 AM.
