Ipod install with NO headunit..........
Posted 11 February 2007 - 07:31 PM
A - I dont have the space in the dash for it and cant stand the underdash pod things
B - I only ever listen to the music on my ipod (never listed to radio etc)
C - I dont want things on display
Have mounted an amp in the boot, run a 2x phono to 3.5mm jack plug lead from the 'input' in the amp to the fromt of the car and attached the ipod, and have connected up my 6x9's mounted in a board under the seat...
It works but all I get is bass, really good bass BUT everything else is muffled and drowned out by the bass.
What am I doing wrong?
Is my amp too powerful or do I need a little graphic amp instead...
I do not want a mega sound system - just to be able to listen to OK quality tunes without having to use headphones...
Any ideas peeps??
Posted 11 February 2007 - 07:53 PM
Try turning the ipod's EQ off and hearing what difference it makes
Posted 11 February 2007 - 07:57 PM
Posted 11 February 2007 - 08:00 PM
What amp and 6x9's have you got? And how have you wired them to the amp?
Posted 11 February 2007 - 08:05 PM
I have somw JVC 6x9's - dont know much else without removing them to have a look - what info do you need??
Posted 11 February 2007 - 08:20 PM
Are there seperate connections on the 6x9's for the tweeters? I can't see any other reason the bass would be so stong, unless the tweeters on the 6x9's were damaged.
Posted 11 February 2007 - 08:23 PM
These looked OK and worked OK in my last car...
either that or add some 4" tweeters to the speaker board as I mounted them towards the middle to allow for 4"ers if necessary...
Posted 11 February 2007 - 08:25 PM
Posted 11 February 2007 - 08:28 PM
I just dont want a headunit .......
Posted 11 February 2007 - 08:56 PM
Turned the subwoofer on the amp off and ................perfect sound!!
Thanks fot your help
Vicky XX
Posted 12 February 2007 - 08:24 AM
Posted 12 February 2007 - 08:36 AM
I had the amp already (cost me £10 off a mate a while back) and the speakers are from my last mini, I had to buy a 2x phono to 3.5mm jack plug lead, but found one on ebay for a fiver.......
I can run Ipod/MP3/phone(with the right adaptor - which I have)/Portable cd/portable dvd or antyhing that takes a 3.5mm jack plug (anything that uses headphones basically)
What sort of sound do you get from your computer speakers - surely they dont go loud enough (shrek has a very loud engine)...
Posted 13 February 2007 - 02:42 PM
Personally, I wouldn't want to run amplified (PC) speakers via an inverter...seems silly when you can get 12v car amps that you can run anything through. Also PC speakers are generally not great quality and pick up a lot of interference (even in houses).
My biggest gripe is finding somewhere to mount speakers, and I hate the look of most car speakers, especially modern ones...they seem to mainly be designed for boyed up golfs etc
Posted 13 February 2007 - 04:28 PM
Make a board to fit under the rear seats (use mdf or buy one off ebay for £10)
Mount your speakers in it - then cover the whole lot (speakers included) with fabric.....
No fugly speakers - and leven less to be seen as a reason to break in!
Posted 13 February 2007 - 04:51 PM
Yeah I've seen those, but they looks like they're not held in very securely, and I don't want to drill any holes really. Also it restricts the massive storage capacity under the rear seat
