Engine wouldnt Stop untill i turned off the lights..
Protarmic
, Feb 11 2007 10:47 PM
6 replies to this topic
Posted 11 February 2007 - 10:47 PM
The other night the engine wouldnt stop untill i turned off my lights. So i thought it was a bad earth, so i put some vaseline around the connection. But today it happened again. Ive noticed that water has been getting in behind my dash.. Anyone ever had this problem?
Posted 12 February 2007 - 12:02 AM
yes, happened to me when wires melted together due to a bad earth!! i think you're guna be looking at taking your loom apart because if its not sorted soon chances are the loom could catch fire if it gets hot again!!
Posted 12 February 2007 - 05:09 PM
sake, ive already had an electrical fire.. Did yours do it all the time? Mines just does it now and then. Maybe theres water sitting in the connector block
Posted 12 February 2007 - 08:32 PM
Where abouts should i look for burnt wires? It only seems to do it if i drive for longer than 15 minutes. Then once you have stopped the engine using the light switch it doesnt do it after that..
Posted 13 February 2007 - 09:59 PM
Happened just awhile ago when i was out driving at night.. Must be when the lights are on for awhile. Can someone help me?
Posted 14 February 2007 - 12:57 AM
i would be suspecting the run from the fuse box down to the front end or where the wires all go thru the front shelf/dashboard.
what / where was your fire??
Posted 14 February 2007 - 09:47 AM
I was thinking about this lastnight. And i came to the conclusion that it as to be after the switch.. lol. So i'll have a look at the fog light switch(ithink?) and at the front of the car. These sotlights tat were on the car caused the fire
