carrys on fireing after ignition turned off
Posted 12 February 2007 - 10:38 PM
Posted 12 February 2007 - 11:20 PM
as above its getting worse and worse and only happens when its warm tks
am no mechanic but im pretty sure this is wut is wrong. i drawed you a dagram so u git wut am talking about. bassicly when ur engen heats up the cable with the key on it expands so it doesnt make contact with the engen so u cool the cable with water or snow and it makes contact
Posted 12 February 2007 - 11:25 PM
Sounds like maybe a timing problem.
Posted 12 February 2007 - 11:34 PM
If you dont have anything usefull to input, dont bother at all, also, learn how to spell.
Posted 12 February 2007 - 11:35 PM
Posted 12 February 2007 - 11:45 PM
That is the worst diagram I have ever seen.
[/quote
Hey Sammy. Im having a problem like this, and with the constant rain for the past 2 days i also have problems with my dizzy and the leads. i have to dry them off and spray wd40 on the points. if the lights are on, it sometimes keeps running until the lights are turned off. Could this all be linked to the dizzy being damp? Im just hopeing for something like this as i dont want it to be a melted wire!
Posted 13 February 2007 - 12:02 AM
they have(should have) a anti run on valve.....
my hif44 has one but isnt connected(not sure how) but im told it will stop the 'run on'
not sure where you can get one from also if anyone could inform on how too connect and where too....
CHEERS!
Posted 13 February 2007 - 12:29 AM
Protarmic, I doubt this is what is causing your car to keep running as long as the headlamps are switched on unless by some fluke you are always switching the headlamps off just when the dieseling stops. You really need to find out if there is a wiring fault because it could potentially be very dangerous.
Posted 13 February 2007 - 12:44 AM
LMFAO
I hope you stay around bigmadbasturd. Maybe you should take over from Dan as technical guru.
Posted 13 February 2007 - 12:49 AM
Posted 13 February 2007 - 11:07 AM
Posted 13 February 2007 - 11:34 AM
I think we have all encountered this before, I had an old Volvo once and it was race to get in the house before the engine stopped!!
You just need to get the basics set, depending on what car it is, check the tappets, points, plugs, timing and mixture. Get these all these correct and if it doesn't stop consider a decoke, it is possible for a build up around the valves to cause the fuel to ignite and prolong the cycle after the power is off.
Posted 13 February 2007 - 11:59 AM
Posted 13 February 2007 - 12:05 PM
LMFAO
I concur!
Posted 13 February 2007 - 12:30 PM
[/quote
Hey Sammy. Im having a problem like this, and with the constant rain for the past 2 days i also have problems with my dizzy and the leads. i have to dry them off and spray wd40 on the points. if the lights are on, it sometimes keeps running until the lights are turned off. Could this all be linked to the dizzy being damp? Im just hopeing for something like this as i dont want it to be a melted wire![/quote]
Buy a pair of Marigolds (washing up gloves), cut the fingers off and poke the leads through the fingers and put the hand over the dizzy.
Keeps the water out!
