Edited by Mini Matt, 13 February 2007 - 05:57 PM.
Is this normal?
Mini Matt
, Feb 13 2007 05:56 PM
7 replies to this topic
Posted 13 February 2007 - 05:56 PM
Ok, tried a search but no joy! Just got my 1380 up and running and im running her in. Problem is after about 15-20 min's if i pull up at some lights and try to select 1st gear it doesn't really want to go in without persuasion. Even then sometimes it crunches slightly. I don't know if its the KAD quickshift or whether straight cut boxes do this as its the first one i've used. If this has been posted before, apologies.
Posted 13 February 2007 - 06:57 PM
shouldnt do it...
maybe clutch drag....
ttfn,
dave
ttfn,
dave
Posted 13 February 2007 - 07:00 PM
check your clutch travel, make sure its been bled out and that the level is ok. it shudnt do what you are describing!
Posted 13 February 2007 - 07:57 PM
I have set the clutch up repeatedly exactly to the haynes manual, turning it the extra flat etc. It has been bled through properly too. The wierd thing is its only first that does it and only when its warmed up. Also ive had a word with a mechanic who worked on minis he says if you heat the clutch arm up and bend it towards the slave cylinder 1/4 inch that may help. Anyone tried that?
Edited by Mini Matt, 13 February 2007 - 07:58 PM.
Posted 13 February 2007 - 08:00 PM
If it crunches when you try and select reverse at the time you are having this problem then it is clutch drag
Posted 13 February 2007 - 08:22 PM
so what should i do if i have set it as haynes says, sorry for sounding daft but i have spent way too much on my mini to set it up wrong. Forgot to say theres a brand new clutch in it should i let everything wear in before tinkering?
Edited by Mini Matt, 13 February 2007 - 08:25 PM.
Posted 13 February 2007 - 09:06 PM
if its any help my car didnt do that till i fitted my quickshift.
Posted 14 February 2007 - 12:25 AM
frankly - that is a bodge used when components are worn out.mechanic who worked on minis he says if you heat the clutch arm up and bend it towards the slave cylinder 1/4 inch that may help. Anyone tried that?
is the arm and plunger in as new condition?
what flywheel / clutch do you have?
