I need some advice. when i turn my headlights, my rear lights fail to turn on. but my indicators work as normal and rear brake lights work so what could be the problems with my rear lights. any help much appreciated
Rusty Clubman
Rear Lights Not working
Rusty The Clubman
, Feb 13 2007 06:03 PM
1 reply to this topic
Posted 13 February 2007 - 06:03 PM
Posted 13 February 2007 - 06:18 PM
Do your Side Lights, Panel Lights & Instruments also work? Because these run off the same fuse, so i'd check the fuse box and ensure the wires are connected properly and the fuse may need changing.
Here's a list of all the fuses:-
Fuse Ratings Link
The fuse box may need a good clean up due to corrosion and the colour wiring colours for the 4 fuse box are:-
White - Green
Brown - Purple
Green/White? - Light green?
Red - red/green
Failing that check the bulbs and wiring for the tail lamps!
Fuse Ratings Link
White - Green
Brown - Purple
Red - red/green
Edited by taffy1967, 13 February 2007 - 06:19 PM.
