MOT Question
Posted 14 February 2007 - 02:40 PM
Im possibly going to be chastised for even asking, but oh well. I have my mini booked in for MOT tomorrow , the only real thing i have a slight concern about is the bonnet catch, since i bought it the bonnet would occasionally fly up when hitting approx 60mph, so i cable tied it, but it has since spent its whole time off the road (with bonnet off) so have just been reminded of the problem.
I am going to see if i can 'adjust' it tonight to get it to work and if not probably order new bits and fix at the weekend. But regarding the MOT, do they have to open the bonnet, if not, i'll just cable tie it, or should i not worry about it as they wont be driving it anywhere really or will they notice and fail it?
Any thoughts?
Posted 14 February 2007 - 02:48 PM
Get it sorted
Second thought:
Yes, they will open the bonnet, they need to check a few things under there! If it doesn't close properly then they will fail it.
Posted 14 February 2007 - 02:53 PM
Second thought, right, i hope it just requires a certian amount of fettling tonight! :'(
Else the brava will be attending another mini meet!
Cheers!
Posted 14 February 2007 - 03:02 PM
It should be fairly easy to sort it. I think it's detailed in the HBOL.
Posted 14 February 2007 - 03:23 PM
Posted 14 February 2007 - 03:39 PM
Posted 14 February 2007 - 03:47 PM
Posted 14 February 2007 - 04:26 PM
Alan...
Posted 14 February 2007 - 04:56 PM
Other than that, get some bonnet straps!
Posted 14 February 2007 - 04:59 PM
Posted 14 February 2007 - 05:37 PM
Posted 14 February 2007 - 05:48 PM
I could probably get some bonnet straps tonight, and after searching and reading all the topics on them, my only question left is, by law (MOT) do you need to retain the mechanical fixing, or are bonnet straps acceptable as a complete replacement?
Posted 14 February 2007 - 07:28 PM
Thay have to open the bonnet to check the VIN plate agrees with what's on the DVLA computer. They also have to remove the dipstick & put down a probe to ensure the oil is up to temperature before they do the CO2 testes.
Alan...
I've never had this on ANY car (mini or not) I've taken for MOT over the years.
Can you not make a bonnet strap from an old leather belt and some rivets?
Edited by minislapper, 14 February 2007 - 07:28 PM.
Posted 14 February 2007 - 10:50 PM
Posted 15 February 2007 - 10:10 AM
Alan...
You should have done if your car has a cat, at least the gas tester I used to have and all others that I've seen had this test.
This is only relevant for a test on a cat equipped car (AFAIK). There is a temperature probe that is inserted into the dipstick hole to ensure your oil temperature is OK before the test is carried out.
Alot of testers don't bother with it, some even have a fag lighter on the gas tester in some garages I've been to so they can heat up the end of the probe and cheat the test! Some garages just put the probe on the exhaust manifold to cheat it!
Edited by mini mad me, 15 February 2007 - 10:19 AM.
