no spark
Posted 15 February 2007 - 09:55 PM
Posted 15 February 2007 - 10:04 PM
Posted 15 February 2007 - 10:35 PM
You may want to download a PDF I put together on ignitions. It has a troubleshooting section.
http://home.mindspri...tsIgnitions.pdf
Posted 15 February 2007 - 11:05 PM
You didn't say if this was for points or electronic ignition. Regardless, start with confirming you have power going to the coil (+) terminal when the ignition key is turned on.
we have checked and there is power going to the coil with the ignition on. however, i also get an earth reading from this cable when the ignition is turned off. is this right. although we havent touched it and it ran before so i assume it must be. itis points by the way.
Edited by nikilah, 15 February 2007 - 11:06 PM.
Posted 16 February 2007 - 02:06 PM
Look through my PDF, including the general overview of how the ignition works. Succinctly, with the wires connected and the points "closed" you will read something close to an earth connection on EITHER/BOTH of the coil low-tension terminals. The readings will be different by 1-3 ohms, but both will look like earth connections when the points are closed.
There are several tests outlined in the PDF and there's also an explanation of what each test is looking for. Basically, you're following the voltage to see where the problem occurs.
Posted 16 February 2007 - 07:19 PM
You still didn't say if this was points or electronic ignition.
yeah, right at the bottom i said it was points. i will run through the pdf and see whats what. i have done all the check recommended by the haynes but they all say i should have a spark. but i dont. so we took it all apart and checked it. incase something had gone amiss when we removed the dizzy to get the engine out. all was fine so we refitted it and set everything. checked connections turned the ignition on and nowt. not a jot. turns over beautiful but not a glimmer. both old and new coil tried. nothing. im sure it is something easy which is why i could do with someone having a look. but the last auto electrician we tried didnt know his arsehole from his earhole.
Posted 16 February 2007 - 08:57 PM
Go through the PDF starting with the steps on testing the coil by itself without being connected to the distributor cap or points. Then add the other components back in the picture one at a time until you find you've lost the spark.
See also:
http://auto.howstuff...tion-system.htm
Take the links off this page for a graphical look at how the system works.
Posted 16 February 2007 - 11:40 PM
Sorry... I obviously missed your statement that it was points.
See also:
will go through it all again cause i am sure i have missed something but i cant see what. will keep you posted.
thanks.
Posted 19 February 2007 - 04:45 PM
