Hi Everyone
I have 28mm valves in a cylinder head but I want to put standard size 29mm valves in. Is it just a case of re-cutting the seats or will it mean the seats need milling first?
David
Bigger Valves
nomininolife
, Feb 16 2007 12:29 AM
4 replies to this topic
Posted 16 February 2007 - 12:29 AM
Posted 16 February 2007 - 09:36 AM
You only need to re-cut the seat, but you need valve seat cutters to do it.... so unless you have them, it's a engineering shop job...
Posted 16 February 2007 - 10:00 AM
Ello,
I'm reading your thing and it says you've got a 998 eninge (I got no idea about valve size to engine size). If your using a stock 998 head then you'd be better off de-shrouding the valves than putting in bigger ones.
Posted 16 February 2007 - 10:46 AM
Hi Adam
Its a 12G295.
David
Its a 12G295.
David
Posted 16 February 2007 - 02:14 PM
Ah,
never mind then.
never mind then.
