How do you fit flip front hinges
Posted 20 February 2007 - 08:48 PM
So far i have worked out that you have to drill the subby and mount the smaller part of the hinge but how do i join the other part to the CF flip front?
Posted 20 February 2007 - 09:14 PM
Posted 20 February 2007 - 09:31 PM
Posted 20 February 2007 - 09:36 PM
Posted 20 February 2007 - 09:37 PM
Posted 20 February 2007 - 09:58 PM
Posted 20 February 2007 - 10:16 PM
Posted 20 February 2007 - 10:21 PM
Thanks that link helps alot with the whole fitting of the flip front process, but it doesnt say how the hinges are mounted, but i looked closely at some of the pics and by the looks of it, it have got the heads of the bolts exposed when you look at it from the front.
those pins are bonnet pins. can get them anywhere.
people fit these into a hole or a drilled hole on the front flat edge of the subframe. they then use deuz fastners on the a panel area to make a removeable front.
when i did mine, i put a bolt through the front and tack'd some hinges onto the subframe, but it was a pain to line up. Make it removable rather then flip, i say.
Posted 20 February 2007 - 10:24 PM
Edited by Tomf, 20 February 2007 - 10:25 PM.
Posted 21 February 2007 - 07:01 AM
Posted 07 March 2007 - 08:53 PM
Posted 07 March 2007 - 08:55 PM
