Does a turbo head have biger valves than a standard 1275 cooper head? and if so will it affect the power out put even more on a 998 mini engine as im looking to fit it.
ty
al
Turbo Head
Alcow20
, Feb 21 2007 10:40 AM
3 replies to this topic
Posted 21 February 2007 - 10:40 AM
Posted 21 February 2007 - 11:07 AM
the metro turbo head head had standard size valves fitted supposed to the N/A mg metro which had a inlet (or outlet) valve 2mm bigger than standard.
The only difference in the standard head and turbo head is the valves are sodium filled to aid cooling/overheating.
Daniel
Daniel
Posted 21 February 2007 - 11:19 AM
you'd have to pocket the block to put a 1275 head on a 998
Posted 21 February 2007 - 01:47 PM
You'll also need to find out what the combustion chamber size of the head is. It'll screw yer compression ratio up if it is wrong.
