Lambda Sensor......
Posted 25 February 2007 - 02:51 PM
Posted 25 February 2007 - 02:55 PM
Posted 25 February 2007 - 03:04 PM
Posted 25 February 2007 - 03:12 PM
Posted 25 February 2007 - 03:23 PM
How about drilling a hole in the exhaust and tapping it?
Thats what i was hoping someone would say.... any particular place it should go??
Posted 25 February 2007 - 03:33 PM
Posted 25 February 2007 - 04:30 PM
Posted 25 February 2007 - 05:56 PM
Posted 25 February 2007 - 06:03 PM
Edited by DJH MINI MOTORSPORT, 25 February 2007 - 06:14 PM.
Posted 25 February 2007 - 06:12 PM
On My Sisters Mini 35 It Has An Emissions Take Off Pipe That's Screwed Into THe Downpipe Which Also Has A Nut Welded Onto It If That's Any Help.
Not really... now i'm completley confused!!!!
Posted 25 February 2007 - 07:12 PM
If you are going to do any real tuning yourself then you need an O2.
To actually tune for wide open throttle you will need a wide band O2. These are different from the stock narrowband O2 sensors.
The NB is only accurate at 14.7:1 AFR. This is only good for normal cruise.
At what you need the mixture to drop to 12-12.5:1 for max power.
The WB O2 operates on a 0-5V scale so it can read a wide range of AFR.
As for location...it is best to put it at the end of the junction so you sample all the cylinders.
Now the further away from the engine the cooler the exhaust gets so I run an O2 with a heater.
The WB will have one anyway.
The install is easy. They sell O2 bungs for less then $20/10 quid
Or you can go to my Innocenti thread page 5 in the mini engine forum and see how I installed 2 of them in my collector.
1 for NB O2 and 1 for a WB O2!!
I just installed an A+ MPI motor in it with an SPI manifold and TB. And I am running a GM DIS ignition and a GM ECM.
I am doing my initial tuning with my NB then will install my Innovate WB data logger to tune the what power!!
Edited by Bill USN-1, 25 February 2007 - 08:12 PM.
Posted 25 February 2007 - 07:22 PM
will it be ok on any one of the branches or should it be where they join??
If you select a single branch you'll only see if that cylinder / pair is running okay, I'd probably place it about a metre from the cylinders, which'd be just after the Y-piece under your car, also means you don't need to remove the manifold, and only the centre pipe and silencer to drill a hole and tap a nut on for the sensor.
D
Posted 25 February 2007 - 08:43 PM
Bill... are you saying that the lamda will only tell me Rich-Ideal-Lean and not exactly how rich or lean... or ideal?? basically, if the fuel solenoid on the nitrous fogger packed up, the lamda tells the controller that the mix is lean and it shuts the nitrous off..... i suppose i could also fit an AF ratio gauge if the lambda will work with it....
998 dave: my nitrous controller will be in the centre console right next to the gear stick so if i tap into the y piece i should be able to come straight in with the wires??
am i on the right track??
Posted 25 February 2007 - 09:29 PM
take care to get it at the right angle tho!
Dave
Edited by Mini-Dave, 25 February 2007 - 09:50 PM.
Posted 25 February 2007 - 09:42 PM
