i just bought a set of stright cut gears, what other parts do i need to fit them?? and what would be good to replace in the gear box during a rebuild??
oohhhh and should i get a set of stright cut drops as well or are the standard ones ok???
cheers
s/c c/r gear box. what do i do??
Nic
, Feb 25 2007 11:37 PM
6 replies to this topic
Posted 25 February 2007 - 11:37 PM
Posted 25 February 2007 - 11:59 PM
I'd talk to good Mr Guessworks Jonesy. He's the gearbox master of the forums.
Posted 26 February 2007 - 02:31 AM
my advic eis send it all to Guessworks along with some spondoolies and get him to sort it for you!!
Posted 26 February 2007 - 08:18 AM
I second that!
Posted 26 February 2007 - 08:42 AM
or see the gearbox rebuild guide in the FAQ's, shows you everything you need....
but in simple terms, to do it properly.. you'll need
1st motion single roller bearing
1st motion spigot bearing
3rd motion double roller bearing
3rd motion nose bearing
Idler bearing
Layshaft & Bearings (would suggest aa high grade shaft or you original if in V.good condition)
4 x baulkrings
Molybdenum competition diff pin
2 x planet gears & bronze thrusts
2 x output shaft mica washers
2 x Steel bound diff bearings
Central oil pickup replacing the standard oil strainer
New seals and gaskets throughout plus primary seal
Complete gasket set required to refit gearbox to engine
The std drops will be ok, but to realised the full benefit of the box I would suggest going SC drops, infact I would rate them higher in order of preference than a SC box.
would also consider an X-pin diff before SC gears..
Idler bearing
4 x baulkrings
Posted 26 February 2007 - 11:00 AM
thanks guessworks thats great,
how much would you charge to do the work as some people have advised???
what is a X-pin diff??
cheers
cheers
