My rad is leaking at the front bottom corner. could it be leaking from the sensor ?
secondly , if i have to replace it could i use an earlier type rad and wire the aux fan to a switch , because funds are tight and later rads seem a lot dearer.
Radiator type
tricky123
, Feb 26 2007 03:04 PM
3 replies to this topic
Posted 26 February 2007 - 03:04 PM
Posted 26 February 2007 - 03:11 PM
Why not pop the sensor out and put some PTFE tape on it?
Posted 26 February 2007 - 03:43 PM
yes i`ll try that , cant see if its leaking from that , need a closer inspection. cheersWhy not pop the sensor out and put some PTFE tape on it?
Posted 26 February 2007 - 03:58 PM
OOOhhh. You don't quite know were it's leaking from. Now I get you. I'd pop it out. Block the pipes off then fill it up to see if I could spot the leak.
there's that or the rad weld stuff.
