Im taking my clutch master cylinder off. took the bolts off, but i cant pull the thing out
Read the haynes manul, but im lost. still learning. could someone pretty please expaline how to get it out.
Thanks for your help...
Posted 26 February 2007 - 04:20 PM
Posted 26 February 2007 - 04:27 PM
Posted 26 February 2007 - 05:19 PM
both bolts out yes.Both bolts out. Did you also disconnect it from the clutch pedal?
Posted 26 February 2007 - 05:38 PM
Posted 26 February 2007 - 05:58 PM
Posted 27 February 2007 - 09:46 AM
Yep, as he said.
There's a clevis joint between pedal and master cylinder push rod. Need to remove the split pin and remove clevis pin - be prepared to swear a lot removing the split pin, especially if it's rusty!
Posted 27 February 2007 - 10:23 AM
Thanks for ya replysYep, as he said.
Did this a few weeks ago.
You need some needle nose pliers and good eyesight (I lacked both at the time) and a torch.
1) Remove drivers seat
2) Insert a thick cloth over seat runners
3) Lay on side/back with heaad under pedals
4) Identify split pin to remove
5) Rotate and pull out with pliers.
I messed around with different tools, while swapping with my reading glasses, finally did it with a 99p draper needle pliers from Tesco!!
One suggestion, replace it with a 'R' clip.
Posted 27 February 2007 - 11:07 AM
Posted 27 February 2007 - 07:37 PM
This is a R Clip
Getting in to rebend a split pin was a nightmare. Inserting the R clip was a doddle.
It is a personal choice though, someone with small hands would manage.
Posted 28 February 2007 - 09:50 AM
Posted 01 March 2007 - 08:42 PM
Posted 01 March 2007 - 09:19 PM
Posted 01 March 2007 - 09:29 PM
What, something like this ?I used an R clip, well 3 of them, they would last about a dozen clutch applications and then it and the clevis pin would be spat out with a bang. I replaced the R clip with a split pin and it has been fine ever since.
David
Posted 01 March 2007 - 10:05 PM
