does any one kno if a pair of SU carbs off a trumph dolmirte 1800cc are sutable for a mini??
Su carbs off a triumph dolmite 1800cc fit to a mini??
Alcow20
, Feb 27 2007 11:43 AM
3 replies to this topic
Posted 27 February 2007 - 11:43 AM
Posted 27 February 2007 - 11:55 AM
Scratch that, their completely different to what I thought.
Edited by Big_Adam, 27 February 2007 - 11:58 AM.
Posted 27 February 2007 - 01:09 PM
If they are SUs, measure the throat diameter. From what I remember, the "2" in HS2 stands for 1 + 2 x 1/8" so the throat of an HS2 should measure 1-1/4". However, the Triumph being an 1800, it's likely that they would be a pair of HS4s similar to what's was used on the MGB. With the proper manifold, replacement of the float bowl alignment/positioning bushing, and re-jetting you can probably make the HS4s work on a high-performance 1275 or larger. I believe Vizard may have some sections in his various books about using these larger carbs.
Posted 27 February 2007 - 01:19 PM
1800 dolomites have twin HS4's, and basically, an HS4 is an HS4 whatever the make of vehicle... yes they can be made to work on a mini, but you will need a Mini inlet manifold and probably change the float bowl angle...
The size of the carb maybe the issue, as DK points out... you need a fairly hoppy motor to get near the airflow rate which the carbs need.
