Moulding bodykit to the body
Posted 02 March 2007 - 03:30 AM
My car is fitted with a zeemax body kit and I am about to get painted and I am thinking about getting the kit moulded to the car for that clean look. I have noticed that most minis with kits use rubber seals between the kit and the body instead of moulding the kit to the car. Is there a good reason for this? Does the mini body twist a little to cause cracking or something? Can anyone help me?
Posted 02 March 2007 - 07:30 AM
Hi everyone,
Best to keep the kit bolted on as you say the body moves about and you dont want to pay to get it resprayed again. Body kits do look better bonded on but it is the risk you take use the smallest amount of filler as you can if you have to.
Posted 02 March 2007 - 10:34 AM
Bolt on kits also enable you to take it off should it look arse....
Posted 02 March 2007 - 02:06 PM
i love the look of a moulded in body kit. but no matter how well its done, its still only a matter of time before it cracks. Plus with mine you need to remove the front part of the kit if you need to get to the front subframe mounts, i think yours will be the same.
Posted 05 March 2007 - 02:04 PM
Posted 08 March 2007 - 02:49 AM
what have you decided to go with? blended in or with seem?
I am going with the seem look...Its the safer bet. How do you instal the seem?Do you fit it to the edge of the fit the but the kit on od do you put the seem around the kit after its been fitted? Where do you get the seem from?
Posted 08 March 2007 - 09:07 AM
Edited by Retro_10s, 08 March 2007 - 09:07 AM.
Posted 08 March 2007 - 12:35 PM
the seem should come with the kit. if you havent got one contact the surply, Zeemax autofashions or other depending on who made your kit.
the non-blending in is defenitly the safer optin. and takes about 3 days less time to fit!
id love to see some picutres when its done, i will post mine up aswell when its complete.
Posted 09 March 2007 - 09:32 AM
Posted 09 March 2007 - 12:25 PM
